CalDreamin
From the article linked: "The total mass of the hydrogen was estimated at 10 to 20 kg hydrogen."
That means somewhere between 1/6 and 2/3 of the hydrogen actually burned in the explosion.
Right, in this particular incident, some of the leaked hydrogen was not involved in the explosive blast. It might have escaped to the atmosphere without igniting. Or it might have burned without being part of the explosive blast.
And not all of the hydrogen in the system escaped. To get 3.5-7 kg of hydrogen into the air, it has to come out of the tank, which will drop the pressure significantly. There is definitely a danger of a large explosion, if the tank is full and ruptures, but I think the frequency of dangerous fires and explosions may be less than with gas.
I agree that the probability of FCV H2 explosions will likely be lower than gasoline fires in an ICE car, assuming the FCVs are well engineered. The point I'm making is that the potential severity of a H2 explosion from a FCV or a H2 fueling station can be far worse than any fire involving a gasoline ICE car.
The reason is that gas pools, evaporates, and burns. The range of fuel/air mixtures that burns for gas is smaller, but because it can pool and continually evaporate under normal conditions, it can have a fume cloud in a burnable state for quite some time, and once it gets started it burns hot for quite some time.
Right, burning for quite some time instead of having much of it burn in a fraction of a second in a supersonic detonation shock wave is the difference between a liquid fuel fire and a flammable gas explosion. Which one would be worse to live across the street from?
Gasoline is very dangerous, and a well engineered tank and safety system for a FCV may well be less risky than having gasoline everywhere in relatively unprotected tanks. In a typical car accident with a hydrogen tank, it is less likely that the tank will fail at all, and if it does, it will probably be a small enough leak or a safety valve that releases hydrogen slowly enough that ignition won't be catestrophic.
The PRD (Pressure Relief Device = safety valve) in a FCV exists only to relieve in specific external fire impingement scenarios. The PRD plug has to melt at high temperature for it to activate. Judging from the Honda CNG explosion caused by an external fire, these types of PRDs apparently don't protect against all fire impingement scenarios. That doesn't surprise me because there can be variations in the intensity of impinging flames, and the orientation of the flames relative to the PRD location on the tank.
The H2 FCV PRD does not protect against other overpressure scenarios because it's not a general-purpose relief device. If the FCV H2 tank or its associated valves, fittings, or piping is catastrophically ruptured by the impact forces of a collision (or from vibration fatigue, or from brittle fracture, or...) then the PRD does nothing at all to help.
A slow leak from a 10,000 psig H2 tank has to be an extremely small breach. There was an incident many years ago that I was involved with, where H2 in a 2000 psig vessel leaked from what a witness later told me was "a hole the size of a period on a page." This ==> . This leak led to an emergency evacuation of all personnel within a large radius. We can manage these risks with all the safety monitoring, systems, inspections, and procedures in remote industrial settings. Joe Sixpack's FCV car won't have the benefit of all that.
It's certainly possible for a H2 tank in a FCV to slowly leak out its contents with no fire at the leak location. In that case, hopefully the FCV was stored outdoors. Because if it's stored in a garage, the H2 can pool along the ceiling until it finds an ignition source, and it doesn't take much energy to ignite H2-air mixtures. An ordinary light bulb or ceiling fan can trigger ignition.
