I installed Tesmanians swiveling display mount for MY.. but it doesn’t sit solidly on the mount. It moves as if it is loose.. except it’s not.. the screws are in tight. The only thing that is moving is the screen and the back display mount itself. The black mount doesn’t move. Help..
Video: sorry for the late reply. I've purchase the up and down side to side movement of the monitor swiveling mount and had the same issue. I had to takr it off and put it back on several times and i was like WTF is going on here. Everything installed properly. Followed the instructions went over it several times but still it was loose. What the problem was is that when putting in the screw/bolt it was going in a slant. So what I did was took off the monitor put a small piece of tape on the screw with some oil. I got some epoxy and filled in the space that the screw was going that was making the monitor wiggle around or loose. When the epoxy was a little hard I removed the scree and let the epoxy cure. After the epoxy was hard I inserted the screw without the tape and checked the fitting. I had to sand it down a little bit. I mounted the monitor back up and everything was good to go. The monitor was no longer loose ( wiggling ) around.
