Perhaps have a live session with Teams so we can all watch and chat about it@terranx Any chance you have a “step-by-step “ for doing either/both config changes? I’d hate to spend the money for a day pass and fumble endlessly trying to find where to change “132 -> 02” and not even know if i did the right thing.
Stream on Twitch and we all chip in for a month license so we can do our config changes.Perhaps have a live session with Teams so we can all watch and chat about it![]()
This is the way.Stream on Twitch and we all chip in for a month license so we can do our config changes.![]()
Understandable bud, if you have anytime in the near future please send me a cut/paste of previous instructions via DM. Much appreciate the community support!I'm pretty slammed with work this week so I haven't really had time to write up a step by step with pictures etc. I've also been hesitating with being super verbose on the public forums, even though realistically Tesla knows people are doing this. The few people who have PM'd me for instructions I did send reasonably detailed instructions.
Would love to get your instructions via DM if you don't mindI'm pretty slammed with work this week so I haven't really had time to write up a step by step with pictures etc. I've also been hesitating with being super verbose on the public forums, even though realistically Tesla knows people are doing this. The few people who have PM'd me for instructions I did send reasonably detailed instructions.
If you are connected via the service shell the commands should be:help me @terranxI need the matrix commands on my S. NEw Headlights are in! just need to program.. Toolbox 3 and local connection are working great too.
Yeeeaahh boyeeee!If you are connected via the service shell the commands should be:
gw-diag SET_CONFIG_DATA 00 28 02
reboot-gateway
The tilt screen change should be:
gw-diag SET_CONFIG_DATA 00 132 02
reboot-gateway
You can combine the commands and then reboot the gateway.
Congrats. You are going to love them!Yeeeaahh boyeeee!
Yes I need to find a flat spot that has at least 25 feet of clearance in front of the car to do this. Can’t do the headlight alignment in my garage.Congrats. You are going to love them!
Don't forget the alignment procedure:
Headlights - Adjust (Global) (Wall Method)
I was getting flashed (the wrong way) when I just guessed on the height.
Same here. I found a parking garage at a nearby hospital that worked. The top level had some good flat area and the wall was high enough.Yes I need to find a flat spot that’s for at least 25 feet of clearance in front of the car to do this. Can’t do the headlight alignment in my garage.
Exactly as I described. Scary at first but just running the immob command separately will fix it.All done. Took a loong time to get the mount in with that freaking lower shroud , but I persevered!
When it came to the VCLEFT replacement, that was surprisingly fast, so was the reboot after!
Then the software decided to fvck with me
1. the “reinstall software” button was greyed out for several minutes and I thought I was fvcked! Then Suddenly it appeared! Phew!
2. The vcleft replacement procedure kept erroring out and I wasn’t even sitting in the drivers seat for a good 10 times. I thought I was fvcked! Then suddenly it went through and messed up at the immobilizer.
3. By now I realized all I have to do is persevere and ran the immobilizer / odometer action and the mechanism check action and it was done! Very anticlimactic!
It might be worth asking your SC how much they would charge for the ethernet port.I purchased a slightly used 2022 Model S that has Steam but does not have an ethernet port...![]()
