I would like to install thicker wire that can easily handle 80A continuous load from the start so that I can add at a later date the twin chargers and HPWC and not have to install all new wiring at that point and instead just change out the 50A breaker to a 100A breaker and remove the 14-50 at the terminating end and wire in the HPWC. Of course it might be slightly more complicated than that as the 14-50 can't take a thicker wire than #4, so I would need some kind of junction box near the 14-50 to convert from the thicker wire to the #4 or #6 wire needed on the 14-50.
That's what Tesla tells you to do if the HPWC isn't delivered in time, although they use a 6-50 instead of a 14-50 (the HPWC doesn't require a neutral conductor, the 14-50 does -- you'll abandon it if you do). See my post above to akula on the temporary install options that does effectively what you're saying -- but yours will just be slightly more permanent.
Can I get the 6-50 adaptor from Tesla even though I have NOT ordered the twin chargers and HPWC with the car?
I guess I can always try and ask. I was hoping to save the upfront $2700 for HPWC and twin chargers and maybe upgrade the car a year or two down the line...
Yes. Reports are they charge $45 for additional adaptors. The 6-50 is available.
