So, I have a 2023 standard range 3. and my beliefs and questions are:
1) My understanding is that the max charge rate is limited to 32 amps by the car whether using the mobile or wall charger. That being the case, it would be pointless installing a 60 amp breaker in the main panel. The main panel is a SC816F200, so a 40 amp double pole breaker would work just fine, using the 80% rule.
2) Given that I will be using my mobile charger until I get around to installing the wall charger, any trash Nema 14-50 outlet will do (expecting wall charger in the next 6-8 months).
3) What material should the conduit be, plastic or metal? The run will be about 35 feet from the main breaker. It will be outside. Plastic is offers insulation from the heat of the sun, metal could conduct heat away to keep electrical loss low, but does not paint well.
4) Should I upgrade wire from 6 to 4? Is power loss that significant over 35 feet?
Appreciate any advice or experience the community has to offer.
