Installing HPWC gen2 , 4 red flashes
Discussion in 'Model X: Battery & Charging' started by Staramerica, Aug 18, 2018.
  1. Staramerica
    Staramerica Member
    Los angelss
    Hi new to the forum. Expecting to pickup my 100D in 7 days! just hooked up the HPWC yesterday. But got 4 red flashes after powering it up. Manual said over/under voltage protection. What does it mean? I did flip the dip switch and turn the dial to 8 (100amp breaker). Thanks in advance!
  2. VT_EE
    VT_EE Member
    Maryland
    Flip the switch? I thought the HPWC came preconfigured for 240V line-to-line? Make sure you have the dip switches correct per the manual. If you changed them, you might need to change back.
  3. Staramerica
    Staramerica Member
    Los angelss
    Yes I tried both up and down on position 1. Same result.
  4. JPP
    JPP Active Member
    SF Bay Area, CA
    Did you measure the voltage coming from the utility to your HPWC??
  5. davewill
    davewill Member
    San Diego, CA, US
    Double check all the connections at both the wall connector and the electrical panel. Have an electrician do it, if you're not qualified. Check the voltage between the two hots (should be 208/240), and between each of the hots and ground (should be 120v). If they're all correct, and the settings are all correct, then you might have a bad wall connector.
