The first sets of cells have been, but I think that's what the new Austin building addresses.Not so sure about the cathode now, it might be a conventional cathode.
I think you’re on to something. Thx.This image of the press mold makes me think the arrows above are pointing to partially filled overflow channels
The patent focuses mainly on the Anode and creating holes in the Anode for higher energy density and faster charging.The first sets of cells have been, but I think that's what the new Austin building addresses.
The most recent patent I could find is:- (dated 25 February 2022)TESLA INVESTOR DAY Something to consider : Tesla Wiring Harness System - New Patent Application published on 9 February 2023 - original Filing Date 21 October 2022 - continuation of application No. 16/271,302 filed on 8 February 2019, now Patent Number 11,479,189
US10861622B2 2018-01-05 2020-12-08 Tesla, Inc. High-speed cable assembly
US11260809B2 2018-01-18 2022-03-01 Tesla, Inc. Wiring system architecture
US11479189B2 2018-02-12 2022-10-25 Tesla, Inc. High-speed-wiring-system architecture
Traditional wiring systems typically connect devices to a central point, such as a processor, using a cable to connect each device to the processor. The processor communicates with each device individually. Typically, the cables transmit data from a device to the processor or from the processor to the device. That is, each cable can only transmit data in a single direction during operation. If one of the cables fails, then the communication to and from the device fails. That is, there is no redundancy. Such loss of communication negatively impacts the overall functioning of the system. When the data transmitted relates to driver-assist and autonomous-driving functionality, such decrease of system functionality may result in complete system failure and a compromised situation.
The backbone has two or more communication pathways. Further, the communication pathways may form loops (i.e., starting and ending at the same device or location, such as a processor) to create redundant communication pathways. That is, if one communication pathway fails, data may be transmitted via the other pathway. The loss of one communication pathway will not result in communication loss. Rather, data may still transmit along the other communication pathway. In embodiments, the pathways transmit data in opposite directions.
The cameras 248-260 and radars 232-246 may generate visual data, sonic data, thermal data, or other data, and then transmit the data to the processor 204 via the device's corresponding hub. A hub may be associated with any number of cameras or radars.
In another example, conductors 128 e-f and 128 g-r may be capable of transmitting data bi-directionally between devices, for instance, a central processor or control functionality and the safety device.
To quickly evaluate what is patented, go to the end of a patent and look for the “claims.” Most of the claims are dependent on other claims, for a quick eval, just look at the independent claims, especially the first claim.
US10461319B2 - Elemental metal and carbon mixtures for energy storage devices - Google Patents
An energy storage device can include a first electrode, a second electrode and a separator between the first electrode and the second electrode wherein the first electrode or the second electrode includes elemental lithium metal and carbon particles. A method for fabricating an energy storage...patents.google.com
Seems like it would take some time to wade though all this and work out what it means, but the Jordan rates it...
So do I...I hope Jordan at The Limiting Factor does a deep dive video on this.
Catapult.This is more of an academic engineering question entirely unrelated to Tesla.
Do you think traction might allow electric planes to reach take-off speed faster, and hence have a shorter runway?
I think any fans or propellers that will drive the plane after take-off are also running at top speed, the aim is to reach take-off speed ASAP.
I am basing this in part of on the Tesla Semi.
On landing, the wheels could also assist with slowing down via regen.
IMO traction seems useful, but it only exists on the ground.
I don't think a sudden loss of the acceleration due to traction after take-off matters, the propellers/fans provide the thrust that is needed, momentum is retained, drag is the main force that needs to be overcome.
While wheel hub motors (or motors inboard through a shaft and right angle gearbox / diff?) would potentially be useful as part of an overall architecture to reduce emissions in the immediate area around an airport, I don't think you'll ever get enough power through them to significantly affect the power requirements for take-off.This is more of an academic engineering question entirely unrelated to Tesla.
I thought @mongo may have been merely citing catapult as an example of maintaining momentum.I haven't found so far anything breaking down takeoff and climb though, so not sure how much you could save by using a catapult as @mongo suggests. For aircraft carriers they're more about space efficiency (short take off area) rather than energy efficiency.
A few years back the Royal Navy (that is, the British one) had an open call out for things to substitute for catapults on their carriers. The rather obvious reason was to launch light and medium UCAVs, plus (big hope of theirs) also enable 'standard' catapult-dependent aircraft of the weight of an F35. There are all sorts of reasons behind this which can be debated endlessly, but the underlying reaso is that the RN deliberately built their two aircraft carriers without catapults. And now they'd like to have a catapult-like capability without ripping the decks completely open and installing eith steam catapults or the electromagnetic rail gun version (EMALS) and all the associated gubbins. Needless to say many folk said "just use a Roadster skateboard". I've no idea what has become of that call for ideas.This is more of an academic engineering question entirely unrelated to Tesla.
Yeah, catapult to impart inital momentum without significant mass/ complexity penalty, beyond landing gear strengthening.I thought @mongo may have been merely citing catapult as an example of maintaining momentum.
Sorry, no.Yeah I also wonder about a kind of launch skateboard for the plane which travels on wheels, then at a launch speed blows air under the plane wings to provide additional lift. On take-off the plane would need to motor up a ramp to get onto the skateboard. When its on the skateboard on propellers are not running to prevent premature take-off and running off the end?
So propellers need to start and get up to speed just before the launch skateboard fires the air blower. That may be able to be triggered by the plane moving forward on the skateboard, indicating that it's speed exceeds the skateboard speed. Or perhaps fired by the plane lifting off the skateboard?
The problem is every new "smart" idea can introduce as many problems as it solves.
