Is a Model S right for me?
Discussion in 'Model S' started by Eagle88, May 8, 2019.
  1. tpnicho
    tpnicho Member
    London
    Ive not used Canary Wharf, mainly because for whatever reason, when you navigate to any other SuC it tells you how many are free, this isn't the case with canary wharf for some reason. I have used Royal Docks but that only has 2 stalls :S, ikea is a good bet to get some good level 2 charging! they also have AC fast and if you can get a chademo adaptor or the CCS upgrade you can get soem good DC from the too
  2. jgs
    jgs Active Member
    Ann Arbor, Michigan
    Me too. It's the only thing I can think of that might make me consider going to back to a gas-burner. (As it is I installed an outlet for my UMC at the rental I'm currently in while my house is being worked on. It wasn't especially cheap but I'm glad I did it. I considered using public charging and saving the money... for about 42 seconds.)
  3. Eagle88
    Eagle88 Member
    UK
    Unfortunately all 100's seem a long way out of my budget.
  4. bhzmark
    bhzmark Supporting Member
    Agreed. So the only choice is do you move or get a new job?
  5. Eagle88
    Eagle88 Member
    UK
    There is a decent amount of street charging nearby and some of the offices I visit (although I can't rely on availability these). I'm not sure how much more convenient these options would be than using superchargers. Do any London owners have experience of using Source? 22kw charging starts at 9.5p/min which seems like a bad deal to me.
  6. AndrewTX
    AndrewTX Member
    Houston, Texas
    You may be putting too much emphasis on the cost of charging in terms of money and not enough emphasis on the cost of charging in terms of your time. Free supercharging is nice but charging overnight or while you are otherwise occupied is the true value of an EV. As others have posted you will quickly tire of sitting at a supercharger while your car charges.
    My advice is to first solve the problem of how to charge at home or at the office(s) and then purchase the car.
