Hi , so my question is what is more cost effective Charging at 48 amps or 32 amps. I know 48 will be faster then 32 . What would the cost difference be between higher but faster versus lower but longer . Any help greatly appreciated. Thanks
The above answer is spot on, with one caveat. 32A is 7.68kW, and 48A is 11.52kW. Depending on you electrical utility they may have different rates for different peak operations draws. Charging at 48A will potentially increase your peak by 3.84kW. If this puts you into a higher rate class, it may increase your overall power bill.The difference is negligible/pennies.
32 = more parasitic loss from the car being powered
48 = more loss to resistance/heat.
It’s not worth thinking about.
Yes, yes, yes. My take is that unless you are coming home with a low battery and needing to leave again in 4 hours on a regular basis and/or have no Superchargers around, 32a is entirely adequate.The difference is negligible/pennies.
This is one of those theoretical things though. You would be hard pressed to find any RESIDENTIAL electricity rate plans in North America that figure in power level demand charges. This is commonly a thing in industrial electricity services, though. I did just hear about one place this past week, though, but that was the first I've ever heard of it coming up in 8 years of reading this forum. So they do exist, but it is very unlikely anyone reading this has that for their house.The above answer is spot on, with one caveat. 32A is 7.68kW, and 48A is 11.52kW. Depending on you electrical utility they may have different rates for different peak operations draws. Charging at 48A will potentially increase your peak by 3.84kW. If this puts you into a higher rate class, it may increase your overall power bill.
Which place did you hear about this past week? Rare today has an uncanny way of becoming common tomorrow.This is one of those theoretical things though. You would be hard pressed to find any RESIDENTIAL electricity rate plans in North America that figure in power level demand charges. This is commonly a thing in industrial electricity services, though. I did just hear about one place this past week, though, but that was the first I've ever heard of it coming up in 8 years of reading this forum. So they do exist, but it is very unlikely anyone reading this has that for their house.
While searching for something else, I found Residential Demand Charge – Columbia River PUD.Are EPE’s residential rate structures changing?
No, the rate structure is not changing. EPE is proposing to change the Summer Season, currently May to October, to June through September. EPE has also proposed opening the Experimental Demand Charge Time of Day optional rate to any residential customer. EPE continues to encourage energy conservation through its rate structures to reflect and recover its costs more accurately. The summer rates are designed to be higher when customer demand for electricity is highest and EPE’s system hits annual peaks. Rates will continue to be lower during non-summer months.
Lethbridge in Alberta Canada, and San Luis Valley/Unites Power in CO have residential demand. As we encounter more bottlenecks with distribution as a result of residential charging, the residential cost of service will be tied to demand. The more capacity you use, the more you will pay for - which is fair in my mind.I do agree they're quite rare for US residential plans.
Our electric co-op started charging by the kw, on-peak. After 8pm, we can charge at any rate.Which place did you hear about this past week? Rare today has an uncanny way of becoming common tomorrow.
That is a good concern, butMy primary concern isn’t cost but preservation of battery life.
...that is irrelevant to your battery. It won't notice or care in the least about you dinking around between the difference of 6 or 7 kW when it is a battery that can handle over 200 kW. That's an unnoticeable difference.I usually limit charging to 24A instead of 32A to produce less heat, the slower the better and most folks have enough time to charge overnight.
noted, thank you.That is a good concern, but
I'm not saying that is bad to do--it's fine. But I want to make sure people do understand that it's not making any difference to their batteries. There is possibly some benefit to not running the charging cable at the maximum level it's rated for. They can get kind of warm, and that daily cycle of heating up and cooling down can cause some wear on electronics and solder joints and such. So it might extend the life of your charging cable some, and I do recommend having it down a few amps for that reason.
