Assuming you're implying that both of those pictures are from the S/X diagrams, can you tell me where you found an S/X that only has a 10 or 20 kW A/C charging system? AFAIK, the oldest ones would do 40 or 80 kW, the next generation would do 48 or 72 kW, and the current generation does 48 kW. Also, since you know so much about electricity, can you explain to me why it's impossible for the electricity from those chargers to turn left in that diagram at the T junction where battery and drive inverter are connected instead of right? Finally, for some super-fun bonus points, can you explain to me why Teslas connected to large enough supplies only draw power after the battery drops 3% when you're not running the A/C but start drawing power immediately when you are running the A/C?
OK, there's never been any Tesla that can do the charging you describe in kW, I believe you meant to say amps. The original S/X had either a 40amp single or 80amp dual charging setup, which (in the US) provided at max, 22.16kW. (80amps@277v). Most charged with 40amps @ 240v for 9.6kW. Skip ahead a few generations, and currently all shipping Tesla's come with either a 32 or 48amp onboard charger.
Everything inside the car is DC powered. That DC current is pulled from the battery (350v to 400v depending on car model), and is stepped down through the DC/DC converter en-route to the various sub-systems inside the car. The majority of which are 12v, but some systems (cabin heat, air conditioning, battery coolant, drivetrain) run at different voltages, but are still DC.
I relate exactly what the repair manual says: "The vehicle recognizes when the AC charge source is connected using CAN communication with the BMS. When charging from an alternating current (AC) source, current flows from the source through the connector to the charge port. From the charge port, it passes through the HVJB (High voltage junction box) and then is routed by bus bars to the on board charger(s). The charger(s) convert AC to DC and supply current to the battery.
The purpose of the HV battery is to provide power to drive the car and run all the accessory systems.
It is the primary energy source for the vehicle. The DC-DC converter also functions as a high voltage junction block, distributing current from the HV battery to the A/C compressor, coolant heater, and cabin heater.
Everything there is DC, and is pulled through the DC battery. AC charges said battery. Yes you may run all these systems through the battery while charging, but they are not AC powered, they are DC powered and there is no DC conversion prior to the main pack. None of the subsystems inside the car run on AC power.
