It does not sound right that the cleaning the ACC filters would use up several kilowatt hours. Any regular day that I hear my AC/heat pump run after parking, I do not see a difference in SOC.
The points below is things we know usually lowers the SOC after parking:
- Wintertime, the battery cools off and Tesla use a principle of displaying lower SOC when the battery is cold than the real SOC. Depending on the ambient temperature that cools the battery and the time, the car could display 1 to 4% lower SOC than the actual SOC (that the car actually knows, but it show a lower SOC.
-When the BMS is off, overestimating the battery capacity the SOC will be adjusted downwards after a drive when the car rests after the drive or sleeps. The longer the drive, the bigger the downwards adjustmen (for a fixed level off BMS capacity estimating fault).
The bigger the BMS estimating fault the bigger the adjustement, combining with the above.
This is how it more or less always looks for me, from todays drive:
After a 50km drive, with a few stops at a shopping area (sentry on - no sleep) I parked 13:02 (1:02PM).
The car was outside at about +4C for 3hrs 15 minutes, then I started the next drive. The car showed the same SOC both after the drive and befo re the next.
Teslafi logs show 53.33% SOC before the first drive (1km drive), estimated about 53.15% when parking and 52.75% before the second, so a loss of 0.4% SOC. Sentry was on and should have used slightly more, but my BMS is probably slightly off underestimating so the SOC probably did gain a little during that 3hrs park.
As usual, the AC/heatpump clud be heard after parking. In this case, most probably shuffleing cabin heat into the battery pack.
Not completely sure but as it seems (others cars discussed at a swedish forum) if the BMS reestimate the SOC downwards during sleep if will be put into the “vampire drain“ column in the energy screen.
If it was the AC/ACC/Heatpump that used the energy it probably would have been put in that column…?
