Wanted to share observation that api/ logging tools on Model 3 disables it from sleeping. Some tools are better than others, though anyone polling the apis at a minute or less refresh rate may cause in the order of >5% loss per day.
I believe if/when “always connected” mode is enabled will help significantly based on S observations.
Just a heads up, this is what was causing constant trickle-charge top-up messages and considerable drain when disconnected from power source.
Another interesting charging / battery observation is I’m seeing 6-11 degree (F) cabin temperature rise when charging...
