Absolutely not. Like I said earlier - I want more EV range (not that it's cost effective or necessarily makes sense). I would love to have a 35+kWh battery pack in my EV. That would give a real-world 100+mi freeway range and would cover all my trips with room to spare except for road trips where I might travel up to 500 miles/day. For that one realistically needs at least a 150 mi freeway range vehicle with 30 minute QC stations at the right spots. For now - easier to go with a PHEV or rent a regular stinker.So you would be okay if they cut the range another 5, 10, or 15 miles (in either car)? Personally, I think every mile counts (people are making a relatively big deal about 3 miles extra range for the Volt). More is always better (besides from cost).
I don't know - range mode's "ideal miles" are based on a constant 55 mph. It seems that if you drive on the freeway at say 65-70 mph, even charging in range mode nets you close to standard mode ideal miles in range, no? But yes - 80% on the LEAF isn't that bad a restriction once you train yourself to hit the timer override button at least an hour before departure (it takes about 90 minutes to go from 80% to 100%, but like the Roadster charge rate starts slowing down in the last 15-20 minutes of charge).As for all the range fudging, I don't think the 80% charge is a real restriction since 100% charge is always an option with no ambiguity. The Tesla also has a Standard mode that restricts the top end, but I have never seen people use the Standard mode charging as the basis to estimate max range.
Definitely - with the LEAF most people seem fairly comfortable driving down to the first low battery warning at which point one has about 3 kWh left or about 15 miles depending on how you're driving before you enter turtle mode. Interestingly, this seems to be a similar amount of energy left Roadster drivers feel comfortable driving down to - perhaps slightly less.The real restriction is how comfortable you are at the lower end (different for every driver), so it'll be some sizable portion of the 21.5kWh usable.
