No.
To start, cyclic aging is only a fraction of the annual degradation. Youre looking at 1% or below. For smaller cycles in medium low SOC perhaps 0.5% cyclic aging each year.
Next part, smaller cycles wear less even if we count per energy and not per daily charge cycle.
The term FCE means Full cycle Equivalent and means that 1 FCE in the graph equals one 100-0% cycle. So a 10% discharge cycle will need 10 actual cycles to count as 1 FCE.
Panasonic NCA close to Tesla cells, cycled from the voltage shown to 0% (2.5V)
As we can see, the lower the charging target the lower the cyclic aging.
100% = 4.2V then 10% lower SOC for each 0.1V, so 3.7V equals 50%.
The cycles are smaller but the battery holds up many more cycles.
4.2V to 0 lost 25% on 750 FCE = 750 actual cycles.
3.7 - 3.8V to 0% lost 10% in 1000FCE, as they are 50-0% two actual cycles needed to get 1 FCE so they was cycled 2000 times (to reach 1000 FCE) and lost 10%
Heres actual tesla model 3 cells taken from a 2018 model 3 and tested:
It is small 10% cycles to one FCE equals 10 actual charge/discharge cycles.
The sweet spot is 35-55% in this test.
They used quite high discharge and charge rate so if they had used power more comparable to how we drive, the lower than 35% might have looked different.
Anyway, lets use the worst case, 5-15%.
Lost about 10% for 500FCE.
A model 3 LR goes about 400km if we charge it full and drives until it stops, right?
Maybe longer but, at least 400km.
500 x 400 = 200.000km, for 10% loss.
Thats 1% for 20K km which is at least about average annual driving range.
This was the worst case, right?
If you do the same in the sweet spot you loose 5% for 1000 FCE, thats 1/4 of the numbers we just calculated.
So, you see that the region causing low calendar aging also actually cause low cyclic aging.
My M3P had 492 km range out of 507km on the last full charge before changing to a MSP. The other cars in teslafi was down to 460-465 km at the same ODO.
I did not have to trade calendar aging vs cyclic aging.
So my car had like 1/3 degradation compared to the other cars, still I had ~55 SuC chargings and 35 charges to 100% during my 2.5 years with that car.
