LED rear reflector turn signals
Reactions: dr3ams
Installed fishbone style plug and play from Ali express. When headlights are off the lights work fine. The signals work correct as well as the brake lights. But when the headlights are on the left reflector blinks rapidly a few times, and then stays on. Any ideas on how to fix.
Installed the led rear reflectors. Easy job on a 2019 build.
Payed 46 euro's here 35.0US $ 10% OFF|2Pcs Voor Tesla Model 3 2016 2022 Model Y 2019 2022 Rear Fog Lamp Remlicht Dynamische richtingaanwijzer Reflector Led Bumper Licht| | - AliExpress
Does anyone have the issue when the headlights are on and the brake is pressed, only the driver side flashes then turns solid but the passenger side just turns solid? Also, with the lights off they just turn solid altogether without the flashing.
Yes, i installed mine today & when i lock the car the left one stays on with the rear break lights while the RHS one turns off, did you fix the issue, if so, how?
This is the one i purchased: https://a.aliexpress.com/_mtkNS62
I have installed these in my first 2021 SR+ and it went perfectly however this issue is on my current 2020 Performance...
I fixed the issue, the accessories cable into the light wasnt installed into the plug correctly.
