Same with ours.'21 M3P, on 44.25.2, the first time I'm not it opened or not (I don't believe it did), the second, it definitely did since I shot some video.
Yes, they will probably fix it with another update. I have one of the early 2021 Model 3 Long Range version, made in US.So we will wait until the next upgrate.
I contacted my Tesla store in France to explain my problem.
Have you got a performance?
Pushed it all the way up, and got the beep, but the trunk didn't dance during the light show
Not a big deal, thanks, in any event.
Yeah I saw that after! Didn’t work! It works if I open the trunk on the app when it should open during the light show, still won’t work automatically though!
Thanks for the link, I’ll watch your videos ! I subsribe.Yes, they will probably fix it with another update. I have one of the early 2021 Model 3 Long Range version, made in US.
Mine didn't open either.I have a 2021 model and it doesn’t open.
Update. Took it to Tesla service they said the power strut was weak and replaced it. Trunk now works with light show. Opens a bit more quickly now as well. So for anyone having issues with the trunk not opening with light show might want to schedule service so they can inspect the power strut.hi guys. 4/20/23 today and attempting new light shows with no trunk open. has anyone found a fix for this? also does anyone know what the factory trunk height setting is? i dont believe its max because when i got the car i ended up moving it up to max because bumping head so i dont think max was a default setting and probably why trunk not opening with light show because i adjusted it to max. i get the attempt to open but then latches again. ive tried a couple different positions with no luck but the trunk works fine otherwise. its a 2021 model 3 sr now on build 2022.45.15 with fsd beta subscription 11.3.6 but same old no trunk open for light show. any ideas let me know thanks.
Did the trunk operate poorly before replacing?Update. Took it to Tesla service they said the power strut was weak and replaced it. …schedule service so they can inspect the power strut.
same here it always opened just not with light show. it was noisy at times i lubed it with grease a few times and it would be quiet for a little while then get noisy again. the new strut i definitely notice the difference it opens more quickly now and they set it to the height i had it which is max. i forgot to ask if the strut was revised at all since 2021 but if yours wont open with light show i suspect same problem. i saw some people on reddit saying power strut replacement fixed their light show problem also.Did the trunk operate poorly before replacing?
Never got the trunk to open for the light show, but trunk operates properly.
Hate to think that Tesla would have to spend (a lot of) money fixing a part that, for the most part, works as intended…just so folks could watch the trunk go up and down as part of the show (that they’ll display a few times, before ignoring it)
I got a 2022 it used to open brought it to service worked for a month then stopped opening again ?I have a 2021 model and it doesn’t open.
Tried it-nope didn’t workI reset the lift gate to factory default (max) and it worked.
I know it years later but how do u set truck do default2020 model here and it opens everytime but most times it doesn't close on it's own.
Going to try the default settings later.
Service can fix but it won’t last2021 model 3 - it never opens the trunk. It tries (motor runs) but nothing happens.
I had the trunk already on max (default). I tried another reset by holding the trunk close button at max opening, but that did not help.
I think something else is wrong with us with 2021 models where it never works. I dont have soft-close working either… maybe some alignment issues??
We all have same problem and service just does a quick fix unless they replace a strut, it won’t comply.I got the XMas update today. I can see and hear the trunk opening for something like few millimeters but that’s about it. I tried already 5 times or so but the same. Initially I thought something is wrong with my trunk or is frozen (a bit cold here today). A bit of a bugger but happy with other updates I got. Cheers!
