Locking the glove box. Interest?
Discussion in 'Model S: Interior & Exterior' started by Chris TX, Feb 17, 2015.
  1. Chris TX
    Chris TX Active Member
    Dallas, TX
    I've often wanted to lock the glove box for various reasons, even when the car was unlocked. There isn't currently a way to disable the glove box button on the touchscreen, so I did some investigation. I've found the connector to the actuator that opens the glove box, and it appears that it isn't controlled by the computer. It seems to have power only when the accessories are powered up. I'm in the process of sourcing the parts for this, but would anyone else like a pigtail that can be used for a hidden switch? This would be a kit where you unplug the actuator and install this harness inline. No splicing. There would be a decent amount of wire for you to run it to a hidden location with a switch (or IC controlled MOSFET) of your choice. I don't see this costing more than $40 shipped. It depends on how much the connectors are.
  2. markb1
    markb1 Active Member
    San Diego, CA
    I'd really like something like this for the frunk, to prevent accidental opening. (I'm concerned if someone else, like a valet, accidentally opens the frunk, they aren't going to close it properly.)
  3. rekoh
    rekoh Member
    Minnesota
    I'd be interested!
  4. Chris TX
    Dallas, TX
    While I have also witnessed a valet mashing all the buttons on my car's fob, pop the trunk, then make a horrible attempt to close it, I don't want to do anything to the frunk. I believe someone did make a keyfob holder that renders one or more buttons unusable. I would start there.
  5. markb1
    San Diego, CA
    Yeah, I saw that. But I think a hidden switch would be a better solution.
  6. Chris TX
    Dallas, TX
    I would also be hesitant to make something that could impede the access to the first responders' loop in the case of an accident.
  7. Danal
    Danal electricmotorglider.com
    Fairview, TX, United States
    Interested. In both (although I believe the newer cars do not have a frunk release??)
  8. markb1
    San Diego, CA
    Don't want to derail your thread here, so just let me know I'll take it somewhere else. But I don't think first responders are going to be impeded. They will just use the lever under the glove box or force the hood open. I don't think they will want to waste time finding and figuring out the fob, or fiddling with the touch screen.
    - - - Updated - - -
    That's correct, but I think the frunk override would be useful with or without the manual release.
  9. Danal
    AH! To override the Fob! I get it now...
    Yes, that would be EXTREMELY useful. Maybe even more so than the glove box.
  10. Johan
    Johan Funds for M3 secured. Contingent on wife aproval.
    Drammen, Norway
    I was thinking today that the button and release for the glove box is obviously motorized so there could be a software option possible here: from the screen choose the option to lock the glovebox using a code, as you press the button (the physical button next to the screen) a query box pops up on the screen asking for your 4 digit code. Possible?
  11. Drucifer
    Drucifer Active Member
    Charlotte, NC
    Doesn't Valet Mode lock the glove box?
    Otherwise, if someone is going to break a window to get in, they are going to break the glove box lock.
  12. markb1
    San Diego, CA
    Indeed.
  13. Johan
    Drammen, Norway
    Is Valet mode implemented?
  14. markb1
    San Diego, CA
    Yes.
  15. Johan
    Drammen, Norway
    Oh cool, I haven't tested it yet. However I might want to have it locked without having the speed and acceleration of the car capped.
    The fact that Valet mode can lock it though proves beyond doubt that it can be software controlled. So it would be easy to make the kind of code lock function I'm asking for.
  16. Chris TX
    Dallas, TX
    Yeah, this is a moot point now that Valet mode is here. It locks the glovebox and the frunk.
