Hi folks--
I replaced the puddle lights in all 4 doors with logo puddle lights. They work great EXCEPT in one scenario, and I am hoping someone here can help me figure out what's going on and how to fix it.
As I mentioned, I replaced the puddle lights on all 4 doors. Prior to installing, I tested each light separately, and they each worked fine. I installed them, and opened each door individually and separately, and everything worked fine...I was about to reward myself with a pat on the back and a frosty beverage for 5 minutes of light (ha!) effort, except I happened to open two doors at the same time, and noticed a problem:
When I open the driver's side front door and the driver's side rear door, the puddle light in the driver's front door became super dim.
I tried every other combination of multiple doors opened simultaneously, and they all work fine. I also tried different sequences of opening the doors, and that doesn't matter either. The problem occurs only when the two doors on the driver's side are open at the same time.
Attached are photos to show you what I'm talking about...1) With only the front door open, 2) With only the rear door open, 3) with both the front and rear doors open.
Has anyone else done this, or seen this issue? Does anyone know how to fix this, or have suggestions for troubleshooting?
