Fair enough. I almost didn't want to share the radar detector because I was worried folks would jump all over that. I could even shut the radar detector off to eliminate it. But that's going a little nuts.
Again, even if vampire drain wasn't that bad, I'm concerned with something running mechanically 24/7 even without any crazy temperatures. When I first got the car and installed the Radar Detector I was initially confused how long it would "normally" take to shutdown. After while I learned and got used to the way it behaved.
There just isn't any way this is normal.
I keep hoping I'll get 48.x and that it maybe fixes it.
I assume this means you’re never hearing the clunking contactors anymore?
A few things I quickly observed tonight.
There’s very quiet clicking that occurs from the charge port (the details are covered in another thread). Have to put your head up next to it. This only occurs in “parked” (idle) mode. When you hear the high voltage contactor “clunk”, the clicking goes away after a few seconds, and shortly thereafter the iOS tells you the car is “asleep”. There are probably other sounds as well, as you have observed.
The contactors seem to take as little as a minute and as much as 5 minutes to “clunk” to off after closing the doors and after the car locks.
One mystery here is sometimes I just hear one clunk, and sometimes two. I know there are separate supply/ground contactors but not sure if that’s what I am hearing or whether there are 4 contactors (two banks?) on the battery. Anyone know? Maybe I only hear two (supply & ground) when it is reconnecting...I’ll have to pay closer attention.
I experimented with using the manual power off - didn’t seem to affect the contactor behavior.
Another thing about the contactors...unless there are two banks which can independently be connected, when the contactors (one for ground and one for supply) are disconnected, this means there can’t be draw from the HV battery. I guess this means the 12V must be drawn on then in sleep mode? Since the HV battery is disconnected... Hopefully there will be wiring diagrams at some point to make this clear - or perhaps someone knows here exactly how the contactors are set up.
As far as I can tell there is no issue with the car leaving sleep mode when you get in proximity to it. I heard no clunking of the contactors, and the iOS widget claimed it was still asleep. So at least on version 46, the car doesn’t seem to exit sleep and go to idle due to proximity of the phone. So that is good.
BTW - only one mile of vampire drain today. So to me that says it was in sleep mode all day (I have been unable to wake it up from the app today, too). I checked my WiFi traffic for the Model 3, and it was a total of 5MB of traffic - very low (I’ve seen near 1GB before, due to a software update). I suspect higher vampire drain days will occur when there is more traffic (presumably it goes to idle for this) but I guess I can check this correlation in future. Note that the single large burst of activity occurred when I was opening the car this evening - probably due to music streaming, etc. Aside from that there was zero traffic. I’m not capturing LTE traffic here of course... but I assume WiFi is preferred, and it is very strong in my garage as there is an access point there.
I did leave it plugged in all day, with the charge target set well below the current charge level. I’m not sure what effect that has on behavior...if it is plugged in, does it replenish the small sleep mode losses from the 12V battery from the UMC? Or does it reconnect the HV battery as well to replenish the 12V when plugged in? I have no idea... Clearly the car will discharge the HV battery when plugged in - but does it discharge slower than when not plugged in, because the HV battery doesn’t have to supply the sleep mode losses? So many questions...
Anyway, those were a few random observations. I thought this was going to be a short post.
