M3 Tire Sidewall
Hi Folks,
Picked up a used set of wheels and tires (moving to 19s from 20s on the M3P). Noticed one of the tires has a weird ring depression on the side wall which is right around the outside of the tire (see pic) like something was sitting on it.
Question: Has anyone seen this before? Any concerns with sidewall weakening or OK to leave it?
Appreciate any input.
That’s what happens to a tire after it’s driven without air pressure. It’s very obvious if you’ve seen it before. Basically, the wheel rim is riding on that spot on the sidewall wearing it down. That tire was probably driven for a few miles without pressure.
I would plan to replace it because the internal sidewall structure will be damaged, independent of how much rubber is missing. And you’ll probably want to replace the other tire on that axle, unless it’s relatively new with little tread wear.
Upvote 0
That tire was definitely driven on while flat. It is garbage and unsafe to drive on. There will be all kinds of rubber particles inside the tire when they dismount it from the wheel where the inside part of the sidewall disintegrated as it was driven on. That junk might damage your TPMS sensor over time too.
Reactions: BigNick and tm1v2
Upvote 0
