Not relevant to this topic, but you might find it interesting if installing multiple 3-Phase car chargers at home.
We rotated the primary phase on each charger.
Charger one : Primary L1
Charger two : Primary L2
Charger three : Primary L3
This means, if you plug in a Single Phase cable, it will default to it's Primary Phase for 7kW charging.
All three chargers can then service three seperate cars at once without load balancing.
Or you can plug in a 3 Phase cable on each Charger for the full 11kW each (but electronically load balanced if needed).
Just different ways of spreading the loads... depending what cable you have to hand
