To recap, there are lots of threads on here. Many refreshed S's (2021+) have excessive negative camber in the rear. This causes excessive tire wear on the inner area of the tires and typically only shows up when running 21" tires. There are lots of ways to remove the excess negative camber. Doesn't really matter how you do it, but reducing it will reduce/eliminate the inner tire wear in the rear.
You can go for the lost option, that you can't adjust, that I personally used and listed upstream. This will likely work for the vast majority of people. If you want to spend more, you can buy adjustable camber arms. The Macsboost ones are about $500 currently and IN2itive about $1200. They both do essentially the same thing. Which is "better" is up to you to determine. Keep in mind that Tesla typically hates aftermarket parts and there are almost always warranty implications.
That is why I went with the simple camber kit rather than a lot of bling. Does it give me the granularity that adjustable camber arms would give me with precise adjustment of my camber? No, it will not. Did it get me out of the zone where I had excessive wear and still good camber for the street? Yes, it did. If my car was an extreme case, I couldn't adjust for it. I find it highly unlikely that anyone was worse than mine with my tires basically gone in 5k miles. So far things are looking vastly better.
If you go with the adjustable camber arms, you should get an alignment afterward. With the camber kit, they tell you what to do so that you might be able to avoid this. This assumes your toe in/out is where you want it to be. It may not be so get an alignment anyway as that is the other reason for excessive tire wear.
FYI - I have no relationship with Macsboost, just a happy customer saving a fortune in tires now.
A good post to read is this one.
Elon is a genius. Shouldn't these vehicles be perfect from the factory? To answer this you must ask yourself for what situation are they perfect for. Is it everyday driving, or is it for breaking records on high speed tracks? For the curious, the stock suspension of the Tesla S and X (and...
www.macsboost.com
