miss demeanor
Lol fair enough!Low efficiency = you did have fun -> Not bad.
High efficiencyyou did’nt have that fun -> Not that good
My M3P ’21 was built in the middle of Q4 2020 (Freemont) and I got it 30/12 (in Sweden). Maybe a longer boat trip from China but otherwise it would be about 6 weeks from build date?When will the q4 cars show up? Is it November?
Do you mean an SR+? Or Performance with LG battery? I don’t think Performance with LFP battery has ever been seen or proposed.M3P is delivered with LFP from china. Due to the extra weight and other characteristics, how much do you think it affects the performance of the car vs Panasonic?
No LFP in M3PM3P is delivered with LFP from china. Due to the extra weight and other characteristics, how much do you think it affects the performance of the car vs Panasonic?
No LFP in M3P
At the moment only the Panasonic NCA 2170L 82kWh battery is used. I think it is only that battery that is approved with the Performance.
I think there was some guessing tgat the new LG 82kWh battery could be used. I think some refered that battery to be a NCMA, but I think it is a regular NMC( LG INR M50).
That might be another question.i find that all a bit bizarre. given how degradation resistant the iron batteries are and how every model 3 P quickly has 10-15% degradation Id honestly rather have a 70kwh battery than a 83kwh battery.
The LFP batteries have much lower power density per volume so the car could not be a long range per definition. I also think that the power density per weight is much lower resulting in a car that maybe do not fit the ”Performance” definition. A long range Performance without the long range and the performance would….
The degradation might not be real degradation, it could be a BMS issue or it could be that the capacity origins way lower than the marked 82.1kWh size. We really do knot know.
2170L is a low cobalt battery and cobalt is among other thibgs needed for longelivery(also performance from the battery side) as I understand it. We might need to weight and see.
Not all M3P have 10-15% degradation.
I think 10% could be seen on the ’19 an maybe some ’20 but 15% is rare?
My ’21 M3P with the 82kWh batt has a NFP of 81.0kWh, thats 1.3% degradation if you do the math from 82.1kWh which insnt maybe the starting point we should use. Highest NFP over time was 81.4kWh so in that case Ive lost 0.5%. 9 months and 23000km.
Absolutely.it is true degradation. range restoration is for a large part a myth.
The average degradation for a 2 year old M3P with 40k kms on teslafi is 462km which corresponds to roughly 69.5 to 70kwh. (around 13% degradation)
I have 68.4kwh on my car and am just below average.
There are SMT captures showing above 78kWh for new vehicles for 2019. And EPA data (easy to look up at Basic Search | Document Index System | US EPA) shows consistently about 79.5kWh, with some small variation on each test article, from year to year, (it’s never been clear what is the reason for the BMS/EPA discrepancy - whether it is “different” kWh, or whether the BMS estimate is conservative and when pushed you’ll get another ~1kWh out of the pack).The capacity when new was 77.8 kWh (full pack when new) and the EPA measurements points to that size?
Oki, copy! Im only about nine months old when it comes to this( started here when waiting for my first tesla less then one year ago).There are SMT captures showing above 78kWh for new vehicles for 2019. And EPA data (easy to look up at Basic Search | Document Index System | US EPA) shows consistently about 79.5kWh, with some small variation on each test article, from year to year, (it’s never been clear what is the reason for the BMS/EPA discrepancy - whether it is “different” kWh, or whether the BMS estimate is conservative and when pushed you’ll get another ~1kWh out of the pack).
I think when calculating capacity loss using the methods available here, it's reasonable to assume 78kWh as the starting point for 2018-2020 (note this number is not applicable to many 2021 vehicles, the subject of this thread...), unless your vehicle did not have full rated range when new (rare, but did happen).
78.6kWh for the early 2021, non-Performance (as we know it now has the 2170L battery - in the US, Europe much more complicated, there are 100 pages in this thread - so this value is no longer applicable). Performance 2021 was 80.8kWh.77.6 kwh from the battery( out of memory).
Could you possibly make a print screen from the teslafi battery degradation that also show the number of cars involved in that data and post, or mess me ? (I would like it for another forum stuff.
I can only see other 2021 M3P, as mine.
I can only choose 2021. As the refresh has another chemistry and size it is probably separated from 2018-2020 because of that?oh really? i can pick whether to see 2018 2019 or 2020 or 2021?
ill attach it when i go back home.
Interesting i cant pick 2021 anymore. Just 2020 and 2019. Probably due to above. 2018 not either for some reason.I can only choose 2021. As the refresh has another chemistry and size it is probably separated from 2018-2020 because of that?
