Hi guys, quick question. So I managed to complete the install of my matrix headlights, but I'm having a really annoying issue where for the life of me, and also with 2 different headlights, the right side will not auto-calibrate correctly.
Once installed, the beam is consistently low and I am unable to use the scroll wheels to adjust the beam positions up. The left unit has no problems at all and has full range of motion with the adjustment but the right unit has about half of the adjustment range. I replaced the unit with another unit from a different seller and it still has the same problem.
Also, I can't adjust the headlights left and right from the menu unless I'm in service mode, has anyone else has this problem before?
Current software version is 2024.14.7. I'm wondering did we incorrectly install the software?
On another note, as I drive, I can clearly see the headlights moving the beam up and down depending if I'm accelerating or braking. And then after a bit, the L and R units sync up and they level out still a little bit low, also ignoring the adjustments from earlier too.
This has been driving me crazy. I'm just trying to brainstorm some fixes for the strange actions of the lights. I've attached pictures. Any help at all would be appreciated.
