Say what?Its probably also the car that debuts significant amount of Tesla model X drivetrain tech
MB-B uses X drivetrain tech?
Highly doubtful - I'm not sure where renim got this idea. If anything, the drive train would resemble the Toyota RAV4 EV as it's a similar conversion of an existing gas model. It's front-wheel drive, not dual motor all-wheel drive, nor is the performance anywhere near what a Tesla offers due to the smaller battery size. There's no reason it would need to use anything but a tried and true system.Say what?
The main difference between the RAV4 EV "conversion" and the B-Class ED is that the BCED started production in 2014, not 2012. The RAV4 EV shares a lot of the early teething problems with the Model S in the Drive Unit. Things like inverter failures and excessive noise from the drive unit are common between the RAV4 EV and early Model S cars. The B-Class ED should incorporate whatever improvements Tesla has made to the drive unit along the way.Highly doubtful - I'm not sure where renim got this idea. If anything, the drive train would resemble the Toyota RAV4 EV as it's a similar conversion of an existing gas model. It's front-wheel drive, not dual motor all-wheel drive, nor is the performance anywhere near what a Tesla offers due to the smaller battery size. There's no reason it would need to use anything but a tried and true system.
A video with parts of the production process of the MB B-Class ED:
Does anyone want to venture a guess what that space to the right of the charge socket will be used for? It doesn't make sense to add a DC fast charge socket there or it would be combined with the AC socket. (@ 1:32)
Its not a compliance car in the CARB sense of the word (although it is used for that), it is a car that is used to get the Mercedes fleet CO2 down in countries where that is required.
USA, EU etc
Its probably also the car that debuts significant amount of Tesla model X drivetrain tech. They would be wise to limit the initial rollout to Germany/ CARB states and increase it from their as their confidence improves.
The Model X diagram shows a full sized motor in the rear and a smaller one in the front (from the unveil, the front motor has half the torque, but is not necessarily half the size). It's unlikely to be a small motor for both wheels given what we know so far (the same motor in the rear allows commonality with the Model S).I don't expect the Model X to use 2 x Model S motors, but rather approximate to 2 x 1/2 size Model S motors.
It is just as likely it's a tweaked version of the same motor as the RAV4 EV (which is FWD, in case that is not clear). 115kW, 273 lb-ft for RAV4 EV. 132 kW, 251 lb-ft for B-Class (in 2013 it was 100kW and 228 lb-ft).My conjecture is that the FWD of MB-B is closely related to the front wheel axle of the Model X
And, I thought NJ might be a CARB state...M-B USA Headquarters
1 Mercedes Drive
Montvale, NJ 07645
I stumbled across NJDEP Climate and Environmental Management.
This pedal-paddle game is fun for E.V. loyalists, but Mercedes drivers will probably prefer something more seamless like the car’s D-Auto mode. In D-Auto, the car’s radar sensors, mostly there for a collision-warning system, are enlisted to automatically set the level of regenerative braking on the fly. The radar locks onto the car ahead, and the precise amount of braking is then dialed in to maximize the amount of energy reclaimed, all the while working something like adaptive cruise control to regulate the car’s speed.
I thought the RAV4EV uses a "detuned" Model S motor... Perhaps because it was the only thing in real production at the time.TIt is just as likely it's a tweaked version of the same motor as the RAV4 EV (which is FWD, in case that is not clear). 115kW, 273 lb-ft for RAV4 EV. 132 kW, 251 lb-ft for B-Class (in 2013 it was 100kW and 228 lb-ft).
Well...I don't understand Mercedes reasoning, why charge extra for the ability to add 17 miles or so to the max range of the car? What additional cost does Mercedes incur in making an 17% of additional range available? The MB website states: "includes added insulation of the doors and roof for to increase climate-control efficiency, along with an electrically heated windshield and a range-extending charge function."
So there is some small cost for door insulation and an electric windshield. But what exactly does MB do, if anything, to the battery? I suspect nothing changes regarding the battery and charging system.
Imagine if Tesla offered a Model S with a standard range of say, 200 miles but for an extra $2,000 the car would go 18% farther, or 236 miles. Pretty much everyone would pay that.
Give the $43,000 base price of the B Class EV why ask people to pay a few hundred dollars for 15 additional miles of range? It should be standard! And the nthe car could be advertised as having a 100 mile range.
