I was wondering how people are getting their best 0-60 times. Traction control on/off? Pressing both pedals prior to launch, range charge vs normal. Etc.
TC on. The wheels will spin even if you try to "feather" the throttle and launching off of sticky track. The Model S won't let you press both pedals either. It is better to have creep mode off so you can just break the beams and wait for the tree with no foot on the break pedal. Then just mash the go pedal on green!I was wondering how people are getting their best 0-60 times. Traction control on/off? Pressing both pedals prior to launch, range charge vs normal. Etc.
Anyone gotten a 0-60 time with 5.8? Wondering if there is any change from < 5.6
Why would there be a change?
I had light aftermarket wheels on the car for a couple of days. They were 10 lbs less per wheel than stock 19s. The car felt snappier. It may have just been subjective. Does anyone else have documented experience with light wheels?
I ultimately made the shop take them back because they were 19 X 9 not the 19 X 8s I had ordered. The tire beads were spread and the wheels stuck out and splashed more on the car. The mounting flange circle which mates against the disc brake was also about 2 inches smaller than stock and the lug nut contact cone was much smaller than stock. They seemed weak in the center spider area.
Rumors of throttle mapping changes in 5.8 led me to ask this question. I wondered if anyone had actual data to support or refute the qualitative assessments made earlier.
I ran 12.37 and got multiple 0-60 times in 3.9 seconds on the street. Traction control off, stomp and go. You can preload a bit by hold down both pedals, but doesn't seem to matter much. The car is without question faster with a higher charge level, I've tested this.
I do wonder if the car is faster with that fuse pulled that allows the car to do burnouts....
So running with traction control off doesn't burn off the tires? I haven't turned it off at all yet, with winter, even when the roads are dry there is salt and gravel on them. I'd rather test the TC off with better road conditions.
