SomeJoe7777
Marginally-Known Member
The post points to the available battery capacity being different in different Model 3 models based on the Rated Efficiency and Rated Range for the Model 3.
No it doesn't. What you are calculating has no relationship to reality because the numbers you're starting with (rated range and rated efficiency) also have nothing to do with reality. Tesla's 310 mile rated range is an arbitrary number. It's useless for calculations to find the real available battery size.
The only number that is physically fixed and real is the available battery capacity in kWh. That number is around 73 kWh. All calculations have to start from this number to have any bearing on reality.
With 73 kWh of energy available in every LR Model 3, the range you can get out of the car will directly depend on what efficiency you can muster with your driving. The more efficiently you drive, the farther you will be able to go.
With 73 kWh of energy available, if you can drive efficiently enough to average 235 Wh/mile, you can drive the car 310 miles. That holds true for EVERY model 3 with the long range battery, regardless of any other configuration. Drive such that you get that efficiency, and you can achieve the "rated" range of 310 miles.
The problem is that it's a bit harder to average 235 Wh/mile in an AWD Model 3 than it is in a RWD Model 3. And it's a LOT harder to do it in a Performance Model 3. Whereas in a RWD Model 3, it's not too hard to actually do better than 235 Wh/mile, and therefore achieve better than rated range.
The EPA calculations are marred by measurements of wall power instead of battery energy, and are then fudged/derated by Tesla. They're useless as far as calculations. The rated efficiency line on the Energy Graph is not particularly useful either. It had little bearing on reality in the Model S when I had mine. In my 85D, I could achieve the rated range of 270 miles driving with an efficiency of 287 Wh/mile. That was hard to do in the Model S, but possible in the dual-motor versions. It was nearly impossible in the RWD cars. However, the "rated" line usually corresponded with a value of 305 Wh/mile or so, and therefore didn't indicate what you needed to achieve with efficiency in order to make rated range.
So in summary, the rated range and rated efficiency numbers are kind of meaningless. Any conclusions you derive from those numbers are also kind of meaningless.
