JeffK
yet you did actually because you said if it came with even 23 more miles of range then you wouldn't get the upgrade. see bolt range vs Model 3 minimum range. 23 mi of range difference.I did not say I only cared about 23.
I said I hope it is more than the bolts range.yet you did actually because you said if it came with even 23 more miles of range then you wouldn't get the upgrade. see bolt range vs Model 3 minimum range. 23 mi of range difference.
you did ... you said if it was more than the Bolt's range of 23 more miles then you wouldn't need the upgrade. Maybe you're saying you misspoke I guess.I said I hope it is more than the bolts range.
Where are you getting "thousands of dollars from?
I spend zero extra dollars if the base range is 250 not 220. Still pay base price either way. You saying a battery upgrade will only give 20 extra winter miles? I wouldn't pay for it then.
SarahsDad,
Elon has already said no need for 400+ mile range.
I can't answer for him, but I do understand his stand in this. Everyone consider buying an BEV should know what distances they do drive on an regular schedule, like daily or weekly. They should also try to establish how real miles correspond with EPA miles (or NEDC) with their own driving style and climate/topology. They should also make a dessication on how much buffer they need/want, no one wants to get home in the evening with 0 miles range left every day. Based on this you have to establish what EPA range you need to get from your new BEV to have a worry free driving experience.Are those 20 winter miles so important that you would spend thousands of dollars on a larger battery? That was my question.
The point was that his choice to get the battery upgrade or not depended on only 23 miles of range. It's not worth it to purchase the battery upgrade if you only care about 23 miles. You might as well stop at a supercharger for 5 minutes.
...and yes the battery upgrade would provide more than 23 miles... but the poster only cared about the 23 per his previous post
The change to 2170 batteries will be a game-changer. J Straubel has said the Model 3 Battery could be 30% more energy dense than the Model S. But look at the evolution of the Powerwall 1 to Powerwall 2. 30% may be conservative. The Powerwall 2 has over twice the capacity with only 20% more weight, in a smaller enclosure, and oh yeah, the Powerwall 2 has an inverter built in. Using a conservative comparison, the 2170’s appear to require 19lb per kWh (13.5kWh in 264lb enclosure) compared to 33lb per kWh (6.4kWh in 214lb enclosure) for the old Powerwall using 18650s, or a 57% increase in power density. (Yes I realize these are very rough numbers - just bear with me)
Lets assume the Model 3 is 20% smaller than the Model S. Using a similar battery configuration to the Model S’ 100kWh battery, a Model 3 battery that’s 20% smaller would be 80kWh using 18650s, but could potentially be as large as 125kWh using the (possibly) 57% more energy-dense 2170 batteries. That would be well over 400mile range, perhaps 500. Don’t you think Elon wouldn’t want to wow the world with a 500 mile 125kWh everyman’s sedan? That would be awesome.
Having said that, I realistically think the max battery size will initially be 100kWh, but 125kWh might actually be do-able.
SarahsDad,
... Elon has already said no need for 400+ mile range. ...
... If you can charge a 75 kwh pack in 15 minutes there is no need for more range, and carrying around all that weight every day is very inefficient.
I'm afraid there's a lot of wishful thinking going on in this thread, don't expect the longest range M3 to have more range than the longest range MS. ...
Also if it weren't for the fact that the 60 is really a 75 I would say don't expect the shortest range M3 to have more range than the shortest range MS. Because the 60 is really a 75 I'd say don't expect the low end M3 to have more range than a 75.
Too bad. I can only hope.
If you are driving 240-250 miles per day then you'd obviously want to purchase the bigger pack. That probably represents a very, very small percentage of the population and of that, the majority could probably buy the bigger battery anyway and consider it a business expense.Having to stop for a 5-minute charge every single day would be a colossal nuisance.
I don't think Tesla is worried at all about Model 3 sales taking away from the S or X. So there is no need for them to deliberately limit what the car will be able do in either range or any other feature. Just as with any other car manufacturer if one version is smaller and lighter I would expect it to get better mileage. Look at the Corolla vs the Camry, the Corolla gets better mileage and I don't see it hurting Camry sales. People will buy one car over another for a variety of reasons, range is just one of them.
Ok, I think I see where the confusion is.Where? Upgrading from a base 220-mile vehicle will cost thousands. Agreed?
I didn't say the larger battery would only increase your range by 20 winter miles. I said you were making your decision on 20 winter miles, which is what you've suggested said several times now. That's what it means when you say a 220-mile battery is not enough and that it needs to be 250+. You are literally intimating that you will spend thousands of dollars to upgrade from a base 220-mile vehicle just because it's 30 regular (or 20ish winter) miles short of your desired range.
Yes, well said. You've summed it up nicely.I can't answer for him, but I do understand his stand in this. Everyone consider buying an BEV should know what distances they do drive on an regular schedule, like daily or weekly. They should also try to establish how real miles correspond with EPA miles (or NEDC) with their own driving style and climate/topology. They should also make a dessication on how much buffer they need/want, no one wants to get home in the evening with 0 miles range left every day. Based on this you have to establish what EPA range you need to get from your new BEV to have a worry free driving experience.
For my self I have calculated that I need at least an range of 200 EPA miles for this. If Model 3 should have been announced with 180 or 190 EPA miles, I would have to consider getting an battery upgrade to get this worry free driving that I want. ... or have to drive slower and/or have to live with a smaller buffer then I'm comfortable with and/or find a way get some charging at the destination (no way I could in my case) or take a detour to spend time (and money) to charge at some fast charger on a more or less daily basis (at least in the winter). So yes, in that thought scenario it would have been worth it even for "those 20 winter miles" - depending on price...
As it is, Model 3 is announced with an EPA range of 215+ miles, so I'm fine. But I would still consider getting an upgrade, depending on the price and extra range I would get. But I have no problem seeing that someone else could have set their target at 230 EPA miles, or maybe 238 EPA miles. If you think that is what you need and you have the money it cost to get that range, I fully support him on his dessication to get it, even if it costs him thousands of dollars and the range difference between what the base range is and what he needs is only 20 miles (EPA). If the range of the upgraded battery is even more then whats needed, he gets more buffers, and that is something you never get to much of
I understand what you're saying and, mostly, agree. My post was in response to the poster who made sound like Tesla would intentionally not give the Model 3 as much range as the Model S.It's not question of "deliberately limiting" what the car will do. It's a question of compromising between the cost of batteries and the range of the car. How many people will be willing to pay for how much range? If they plan on building, say 400,000 cars per year, as a random number, and they know they'll sell all of them, but of those, only 25 people would pay for a 500-mile battery pack, they won't offer it because the market does not justify it.
The lighter car needs less battery for the same distance. Some people would pay for the bigger battery, but others will prefer to save money on the price of the car. Judging how many people will be willing to pay for what range is how they'll decide what ranges to offer.
I'm in a small minority of people who would pay for a 500-mile car. I don't expect to see that in what remains of my lifetime. But, as I said, I can dream.
