Anyone done any testing to measure the M3's internal charging efficiency? Here's a MS thread that shows pretty interesting data, but I'd like to know the most efficient setting for the M3....
This report is half the equation (like @SageBrush says), the other half is HPWC in vs out. Each of the two systems may have their own sweet spot and trying to find the best combination is what im interested in. I would discount instalation specific loses (like long runs that produce extra resistance)The API are supplying this data to my understanding, so I get the charge efficiency data on my teslafi.com page for my S.
You can get the two first week for free or you are welcome to use my referral code for a free month, which is Veritas (case sensitive).
Ah, my mistake. I get what you are trying to acheive now.This report is half the equation (like @SageBrush says), the other half is HPWC in vs out. Each of the two systems may have their own sweet spot and trying to find the best combination is what im interested in. I would discount instalation specific loses (like long runs that produce extra resistance)
If I understand the data posted by @Veritas1980, it is really what you want, but for different current settings. That is showing the efficiency of everything inside the car because it is showing kWh AC vs. kWh into the battery. In a Tesla, the cooling pumps and fans consume a non-trivial percentage of power when the charging current and/or voltage are low (120V household outlet for example). The EVSE is going to take a fixed amount of power to operate, mostly the coil keeping the contactor closed, so that is going to give the smallest percentage loss at the highest current. Everything else is is resistive losses in the cables, which you seem to be willing to set aside.This report is half the equation (like @SageBrush says), the other half is HPWC in vs out. Each of the two systems may have their own sweet spot and trying to find the best combination is what im interested in. I would discount instalation specific loses (like long runs that produce extra resistance)
Isn’t that the higher the voltage the more efficient the rating instead?You need to measure the total energy supplied versus the amount that gets to the battery.
Generally the internal car charger loss does not increase as fast as the amount of power going in so the higher the power the more efficient the charging.
Some examples based on numbers I have seen:
110v @12 Amps = 1.3Kw - from your outlet.
Subtract the 400 watts loss and only 900 watts is going to the battery.
About 70% efficient. 900/1300=70%
240V @ 40 Amps = 9.6Kw - from your outlet.
Likely about 900 watts loss for 7-8x the energy
About 90% efficient. 8700/9600 = 90%
One reason to get a 240 volt setup. You will use less electricity.
Bottom line:
The higher the power the more efficient the charging.
For the same amperage because the fixed losses will be lower (less time)Isn’t that the higher the voltage the more efficient the rating instead?
This is more or less what I am after, only I'd like to see which settings maximum the charging efficiency because I can pick from multiple charge rates in the Tesla GUI....Edmund's is doing a long-term test drive of the Model 3. So far they've published 2 monthly reports/updates. In the first of those monthly reports, they listed both the measured average wall-to-wheels efficiency AND the displayed average battery-to-wheels efficiency (as displayed on the touchscreen).
Here are the results:
Current odometer: 1,388 miles
Average lifetime consumption: 302 Wh/mi
Average onboard consumption meter: 251.7 Wh/mi
Monthly Update for January 2018 - 2017 Tesla Model 3 Long-Term Road Test
So they observed a 83.3% charging efficiency. (Or, if you prefer, a 20% charging overhead.)
Hopefully they'll post the displayed efficiencies in more future reports, but since they chose not to in the 2nd report, I'm not optimistic.
If you're in the car and in park, the car is counting the amount of energy used. You can see this by resetting a trip meter and blasting the HVAC for a bit before driving off.Adding this thought - I seem to recall somewhere reading that the usage the car reports is for driving only, not 'idling'.
