"Take Control"
Why?
It hugs the medial double-yellow line at all times!
BTW, this becomes a nuisance when single lanes splits into double-lanes before an intersection, with the left lane usually reserved for left-only turns....
Of course the owners manual tells you AP is explicitly not intended for use on roads like that (or on roads like the one the OP posted the video about).
Why do people keep acting shocked when AP doesn't work correctly on roads that Tesla directly states it's not intended to be used?
Model 3 owners manual said:Traffic-Aware Cruise Control is primarily intended for driving on dry, straight roads, such as highways and freeways. It should not be used on city streets
Model 3 owners manual said:Warning: Do not use Traffic-Aware Cruise Control on city streets or on roads where traffic conditions are constantly changing
Model 3 owners manual said:Warning: Autosteer is intended for use only on highways and limited-access roads with a fully attentive driver.
Model 3 owners manual said:Do not use Autosteer on city streets, in construction zones, or in areas where bicyclists or pedestrians may be present
I can only assume you haven't actually read it. I AM HERE TO HELP!
https://www.tesla.com/sites/default/files/model_3_owners_manual_north_america_en.pdf
If you want to keep complaining "SYSTEM DOES NOT WORK RIGHT IN PLACES I WAS ALREADY TOLD IT IS NOT SUPPOSED TO WORK RIGHT" you can I guess... you do you
Tesla "System is not supposed to work" statement fully applies to ALL road situations, other than straight, traffic-free highways, at speeds under 50 mph.
Te
I can't help you further if your reading comprehension is preventing you from absorbing the information plainly stated in the Model 3 manual.
a
The system is not supposed to work on roads ! Where do I sign up ?
... my m3 with fsd can not even tell which lane to go into in a lane split even when there are painted lines showing to go into the right lane. I am traveling at 70 when it happens, speed limit. If I am traveling at less than 50 it will make a decision.
