shlidgn90
I was told by the Colma SA earlier this week that my vin number would show up today. But nothing as of yet.Not me. I ordered white/white on 7/27![]()
No, you will not have access until your appointment time. Then you need to accept delivery in the app by clicking a button. After a few minutes you should have full access to the car in the app and you can set up the phone key, etc. If you are seeing it early, someone messed up and put the wrong time inIs it normal to have access to your car through the app before taking delivery? My appt. is 3 hours away, but my app is now showing the car controls (set up phone key - controls - climate - location, etc)
Try putting something behind it to make contact between the back and the pad: Picture a case that makes the bump flush. I think the problem is that you have an air gap, and most Qi chargers will go through a case. If you don't want to use a case, try some other material to eliminate that gap. Or the problem could be that the phone is so big that its "power spot" isn't lining up with the pad's and then you are probably SOLI just checked in my model 3and confirmed that with the iPhone 13 pro max you canāt use the wireless charger due to the larger camera bump.
Well, I have access and it shows two cars. Both with the same vin.No, you will not have access until your appointment time. Then you need to accept delivery in the app by clicking a button. After a few minutes you should have full access to the car in the app and you can set up the phone key, etc. If you are seeing it early, someone messed up and put the wrong time in
Yes the car had temp paper plate installed on the rear and the front paper plate on the dashboard. Frame for the front plate was in the trunk as well as charging cable bag. That's all that came.Thanks, but did you get the CA temp registration and temp/paper plates? What did they include in the car at delivery?
I really hope this works when I get my car or else Iām going to be really sad. I just got my 13 Pro Max a couple hours ago..Try putting something behind it to make contact between the back and the pad: Picture a case that makes the bump flush. I think the problem is that you have an air gap, and most Qi chargers will go through a case. If you don't want to use a case, try some other material to eliminate that gap. Or the problem could be that the phone is so big that its "power spot" isn't lining up with the pad's and then you are probably SOL
Just got my VIN. YESSSSSS!!!! let us know when you are able to schedule deliveryYou must be next since we have the same car and live near the same place.
I have my iPhone 13 pro max with case. Maybe I need to get a thicker case. I use apples case.Try putting something behind it to make contact between the back and the pad: Picture a case that makes the bump flush. I think the problem is that you have an air gap, and most Qi chargers will go through a case. If you don't want to use a case, try some other material to eliminate that gap. Or the problem could be that the phone is so big that its "power spot" isn't lining up with the pad's and then you are probably SOL
Congrats! Weāve been on the same timeline so iām hopeful iāll get mine today too.Updating when it changes. Ordered 7/27 LR/White/White/19
8/4 EDD 9/6-9/26
8/7 EDD 9/8-9/28
8/11 EDD 9/7-9/27
8/13 EDD 9/8-9/28
8/16 EDD 9/14-9/30
8/17 EDD 9/7-9/27
8/18 EDD 9/15-9/30
8/19 EDD 9/14-9/30
9/12 EDD 9/13-9/25
9/14 EDD 9/15-9/25
9/16 EDD 9/17-9/30
9/17 EDD 9/18-9/30
9/19 EDD 9/20-9/30
9/21 EDD 9/22-9/30
9/22 EDD 9/24-9/30
9/24 EDD 9/26-9/30 VIN ASSIGNED
Even with a case on?I just checked in my model 3and confirmed that with the iPhone 13 pro max you canāt use the wireless charger due to the larger camera bump.
Update - Just got my vin!!! 10 weeks exactly from my order date on 7/16, EDD still shows 24-30 but I expect that to update tomorrow.Congrats! Weāve been on the same timeline so iām hopeful iāll get mine today too.
WOOOHOO congrats white on white brother!Updating when it changes. Ordered 7/27 LR/White/White/19
8/4 EDD 9/6-9/26
8/7 EDD 9/8-9/28
8/11 EDD 9/7-9/27
8/13 EDD 9/8-9/28
8/16 EDD 9/14-9/30
8/17 EDD 9/7-9/27
8/18 EDD 9/15-9/30
8/19 EDD 9/14-9/30
9/12 EDD 9/13-9/25
9/14 EDD 9/15-9/25
9/16 EDD 9/17-9/30
9/17 EDD 9/18-9/30
9/19 EDD 9/20-9/30
9/21 EDD 9/22-9/30
9/22 EDD 9/24-9/30
Excellent, did he tell you when?I just called my SA, so apparently my car was 'born' as he called at 6:30AM today at Fremont and they just moved it to Daly City for delivery. I wonder why they don't just deliver directly from the factory to Service Center but whatever. He also said they would deliver to my new place in Milpitas so that's exciting.
