Model 3 mud guards
Would you guys recommend installing some clear PPF before putting on the mudflaps?
I would recommend it. About a month after getting my car, I had the whole front end fully PPF'd. But wanted to protect the rockers from stone chips and sand blasting like so many pictures I'm seeing about paint wearing out. So I ended up getting these eBay/China mudflaps. However, prior to installing them, I ended up PPF'ing the lower doors and rockers myself. Once this was done, I was able to install my front mud flaps, as there was PPF everywhere the fronts would be against.
As for the rears, I haven't installed the mudflaps yet, because I want to test mount them with a piece of paper underneath the sides of the flaps. That way, I can trace the outline of the flaps and then trace and cut out some PPF to install underneath and just about 1/4" outside of where the rear mudflaps will mount.
--Cintoman
Amazon splash guards
I ended up going with the Basenor Amazon Mud Flaps. I didn't want to drill a hole in the front fenders so I just used double sided 3M tape on the side edges. If that can hold on my spoiler, I'm sure it will hold these on. I just put on the tape without removing the backing, then pulled a bit of the backing to created a pig tails on the red part of the tape and then screwed it on. When it was secure on the bottom, just pulled the pig tail from the 3M tape and pushed down. Worked great.
Reactions: jebinc
Just curious, are these the same ones as many of you installed? Where a hole drilling is need to properly secure it in the front for certain vintage model 3?
For Tesla Model 3 2016-2019 Car Mud Flaps MudFlaps Splash Guard Fender Mudguard | eBay
Just curious, but might end up buying from Amazon from above links
https://www.amazon.com/gp/product/B...sin_title_o00_s00?ie=UTF8&psc=1&tag=tmc064-20
If i wanted to paint them, in my case white, what kind of paint is needed? I saw a photo here of white, not sure how i feel splash guards being off color...
