I used the 3M tape on the edge of the car fender, not on the black lining, black lining is too loose to work. This pic will help, ignore the dent, I just found this picture online of the fender. See the small white part going into the inside edge of the wheel well? Put it along there.Would you mind elaborating a bit more on how you installed it using the the tape? I'm about to install the two front mud flaps but don't want to screw into the liner. Just a bit confused on how exactly you did it with the 3M double sided tape.
Full disclosure though, I ended up drilling holes a few weeks later. I had a lot of anxiety about it and just decided to it, it really is such an easy thing to do, the black lining is as thin as cardboard. Just use the smallest drill bit you can so the screw can catch it and expand the hole When you screw it in, a 1/16 drill bit worked for me.
