Perry
I see talk about Tesla changing control arms for the larger 20" wheels. Does this mean if I get my model 3 with 18" wheels and want to change to 19", I'll have to also change my control arms?
But why are they changing the control arms? Will the 20" not fit otherwise? What if I later want to put 20s, will I have to change my control arms?Tesla only includes the suspension change in the 20" tire package. So you should be fine going to 19s.
So then I am assuming that all those who bought the car with Aero 18" wheels and upgraded to 20" wheels are now having alignment problems due to the inability to do proper camber adjustment?They don't change the control arms, they only change the rear upper fore links. I assume it has to do with the camber adjustment.
I don't know if you would need to revert to the original fore links to go back to 18" or 19" wheels. (The site doesn't say anything, and the manual doesn't mention them at all.)
I understand but why would the fore links come with the 20" unless the the ones that come with the 18" wheels where inappropriate for putting 20" wheels on them.The 20" tire package comes with the rear fore links and are installed at the same time as the tires/wheels.
If you just want to go cosmetic, Evvanex sells M3 red caliper covers for $249 and alloy pedal covers for $49.Trying to decide on the $5k performance upgrade, does "Performance Brake Calipers" mean just painted red, or are they indeed different?
To clarify some confusion about the suspension changes with the $5k Perf Upgrade which includes the 20" wheels:
The suspension changes are not related to the 20" wheels, they are related to the suspension sitting 1cm lower. When you install shorter springs, unless the car has adjustable camber from the factory (such as many BMW products), you will need a "camber kit" in order for your tires to still be in-spec camber-wise. Tesla's installing this kit for you. This means that you are free to change to any other wheels you wish, such as the 18" Aeros, without a worry in the world -- your car will still be 1cm lower than a stock TM3, and camber will still be in spec.
I don't get why 20" wheels need new rear upper fore links. Does this have to do with lowering? It doesn't look like it since they would not be lowering the car when you install 20" post sale. And then why only rear links? Are they lowering the rear only?Can’t argue that lowering the car affects camber but you can purchase the 20” tire package from the Tesla store for the RWD non-lowered car that is described by Tesla as:
“Upgrade your Model 3 with 20” Sport wheels and Michelin Pilot Sport 4S tires for enhanced performance and style. This package includes rear suspension adjustments to optimize ride quality, and is only available for installation after delivery.
Note that high-performance wheels and tires may affect your range.
Includes:
It is the rear upper fore links that were being discussed initially.
- 4 x 20X8.5J Sport wheels
- 4 x 235/35/20 – Michelin Pilot Sport 4S tires
- 4 x tire pressure sensors
- 4 x Tesla logo Sport wheel center caps
- 2 x rear upper fore links”
I think Tesla updated the Model 3 comparison page and listed the lower suspension as possible upgrades to the performance package. It doesn't tell us if the 20" wheel setup is directly related to the 1cm drop or not however.Yeah- that's the question.
(it remains unclear if ONLY the P with 20s is lower, or if all Ps are)
Where is this page? and what do you mean by "performance package", the performance upgrade or the base performance?I think Tesla updated the Model 3 comparison page and listed the lower suspension as possible upgrades to the performance package. It doesn't tell us if the 20" wheel setup is directly related to the 1cm drop or not however.
