I wrote the answer for that in my previous post but then deleted as it got too long.
Closing the lid is possible, though opening it would still happen with actuation. Which still requires mechanism, wires, etc.
And closing with a snake would likely scratch it. If snake would have soft edge then it would wear out which is also not ok.
To those who speculate about the card in cupholder. It can not be a key as Model 3 will likely have keyless access.
That means key must have a battery. Inducing enough current wirelessly for sending rolling+fixed codes to the receiver is not happening.
Without battery it would be able to work at no more than 5-15cm (like NFC tags), depending on antenna size.
Though buttons on the remote are actually not necessary for trunk access nor vehicle locking. Model 3 will not have power liftgate option. It will be manual. Most buttons have no point. Though with frunk having button on remote is more simple and cheaper solution. I would even consider no frunk button on remote acceptable. Frunk will not be "a daily thing" anyway for most of us.
Very small buttonless dongle/toycar on my keychain is fine. Though this DEFINITELY requires charging port to be sensitive to pressure.
