That's a great idea, I should try two base to base, I did not try that.Thanks for posting your results! I love it.
Can you fit the two snowboards using config #4 base to base (stacked in the center)? I think that might be the most aerodynamic of all by a decent margin. Also, if there is a roof-top sport box that mounts with T-mounts and can fit two boards stacked inside the box, that might be even better.
I'm looking for a small but long ski box for the Tesla rack system, anyone have any favorites?
Something like that, it's interesting how little of an impact the rack on it's own does. Assuming all things linear (they're not) and doing some cringeworthy estimating: 5mph slower = -24.7Wh/mi -- 1mph slower = -4.94Wh/mi -- Rack = +4Wh/mi -- Need to go 0.8mph slower to compensate for the rack.Correct me if I'm wrong, but doesn't that imply the range hit from the Tesla rack (bare) can be compensated for simply by driving about 1.5 mph more slowly?
Did you see the pictures here? Model 3 Roof Rack Options - Comparing EfficienciesCan you post more photos of your setups?![]()
The FatCat 6 is awesome and goes on/off super quick and easy. My old Thule (in the SeaSucker photos) was a major PITA and I hated doing it once a season. The SeaSucker comes on/off very quickly as well, I used it for a few months with bike racks and did not mind mounting it before each ride.How hard are the different racks (the ones attached to the M3 roof) to take off & put on? I personally only want the racks on part of the year for snowboarding or longish road trips and want them gone the rest of the time.
As winter arrived I was excited to strap a roof rack on my Model 3 and take it to the mountains. I quickly discovered little information out there about how it would impact the range. Given the long cold uphill drive and variable weather conditions, I was determined to find the highest efficiency setup and characterize it for route planning. I started with a stock TM3 LR AWD, keeping as many variables constant as possible, and did 20+ runs up and down the highway gathering data. I tested with both the SeaSucker Monkey Bars and Tesla's Roof Rack, with various configurations of snowboards, carriers, and fairings.
Additional pictures, charts, and raw data: Model 3 Roof Rack Options - Comparing Efficiencies
TL;DR compared to stock TM3 LR AWD 18":
Test Procedure
- Tesla Roof Rack -- 1.6% range loss
- Tesla Roof Rack + Yakima FatCat 6 Evo -- 17.3% to 19.6% range loss
- SeaSucker Roof Rack + Thule 91725 Flat Top Ski Carrier -- 26.7% range loss
- Aero Wheel Caps Removed -- 5.4% range loss
I avoided traffic during the trials to not skew the data and threw out any significant outliers due to road conditions. I tried to test when the wind was at a minimum but this seemed to be the most significant variable I couldn't completely control.
- Get on the highway going 70mph with autopilot engaged and reset the trip meter.
- Drive 6.5 miles south, gaining about 130 feet in elevation.
- Log the Wh/Mi, disable autopilot, and get off the highway
- Get back on the highway going north and do the same thing again. This time losing about 130 feet in elevation.
- Average the north and south results together.
Controlled Variables
Configurations Tested
- 55-60°F outside temperature
- Dry highway road, minimal wind
- 70mph on autopilot
- HVAC off
- Radio @ 25% volume
- Tires @ 42 psi cold
- Baseline: Tesla Model 3 Dual Motor Long Range, 18” Wheels w/ Aero Wheel Caps
- Config 1: Aero Wheel Caps removed
- Config 2: SeaSucker Monkey Bars, Thule 91725 Flat Top Ski Carrier, 2 snowboards bindings down, Yakima Wildshield Fairing 46” [Picture]
- Config 3: Model 3 Roof Rack, Yakima FatCat 6 Evo T-Slot mounting, 2 snowboards bindings up (T-Slot mounts too low to put bindings down) [Picture]
- Config 4: Model 3 Roof Rack, Yakima FatCat 6 Evo standard mounting, 2 snowboards bindings down [Picture]
- Config 5: Model 3 Roof Rack, Yakima FatCat 6 Evo standard mounting, 2 snowboards bindings down, Yakima Wildshield Fairing 46”
- Config 6: Model 3 Roof Rack
Results and Real World Impact
At the end of the day I care about how much time I spend on the road. To that end I plugged the Wh/Mi figures for each config into ABetterRoutePlanner to see how they would impact the round trip driving time to my favorite ski resorts.
Wh/Mi Δ / Range Δ / Time Δ
1. No Aero Caps
+5.7% / -5.4% / +7 minutes
2. SeaSucker
+36.4% / -26.7% / +44 minutes
3. Tesla Rack + T-Slot
+24.4% / -19.6% / +28 minutes
4. Tesla Rack
+23% / -18.7% / +26 minutes
5. Tesla Rack + Fairing
+21.0% / -17.3% / +24 minutes
6. Tesla Rack Only
+1.6% / -1.6% / +2 minutes
Accuracy
For each config I did two or three round trip trials. On average the trials within a config varied by 2.2%.
Cabin Noise
I measured cabin noise for each config using the iOS app Decibel X. The absolute values are probably not too accurate, but the deltas are somewhat interesting. The baseline measured 83dB.
- Config 2 (SeaSucker) measured 84.5dB. Without the fairing the app measured lower but the sound was much more unpleasant. Likely due to the frequency of the noise and concentration at that frequency.
- Configs 3 and 4 measured 86.5dB and 86.1dB respectively. Config 5 (fairing) measured 86.7dB and was actually more unpleasant due to a small gap between the fairing and the rack+boards.
- Config 6 (Tesla Rack Only) measured 85.1dB but didn't sound too different from the baseline in practice.
Speed Impact
I repeated testing of Config 6 going 65mph instead of 70mph. The Wh/Mi decreased by 9.9%, causing the range to increase by 11.0%. No big surprises here, but always interesting to verify physics.
That is very interesting Data! I was also searching for the most efficient way to carry skis to minimize range loss on cold winter distance trips. I have added a trailer hitch to all of my past cars and also to the Model 3 to help make the car as capable as any SUV...
I found the shortest Ski pod capable of carrying 4 sets of skis and gear and built a trailer hitch adapter.
I made a test on a 10 mile stretch of highway at night to avoid impact from other cars. For the test w accelerated to 70mph, set cruise control, reset trip odometer, continued driving 10 miles, collected data and turned around.
Results: There is a slight efficiency improvement which is likely within the measurement error. I have another test with a different pod and also a bike rack which I can post later.
The Model 3 is extremely capable of tackling any adventure!
Nice! How’s trunk access with that thing mounted?That is very interesting Data! I was also searching for the most efficient way to carry skis to minimize range loss on cold winter distance trips. I have added a trailer hitch to all of my past cars and also to the Model 3 to help make the car as capable as any SUV...
... I have added a trailer hitch to all of my past cars and also to the Model 3 to help make the car as capable as any SUV...
adapter....
I’m confused...wouldn’t your bindings be facing up or sideways?Thanks for the data!
I wish I could run the Smart TSlot 2 for the fatcat but my skis would be banging on the glass if that was the case (it's only about 4-4.5" clearance and my bindings are 5"). Will make sure to budget at least 20% extra energy for the first time using the ski rack!
Thanksfully to tahoe/mammoth and back from san diego there are plenty of superchargers.
Yakama told me today that it’s not a good idea to keep the rack attached as the mounting components are steel and will rust over time.Whoops, sorry for the late replies, I had been getting email notifications and they stopped coming in.
The Tesla rails themselves aren't that hard to put on and off, maybe 5-10min once you get good at it. There's these metal j-hook brackets that you install first and then push rubber bumpers down over them. It's a little tricky to get those bumpers down over the hooks far enough that the threads will catch so that can take some fiddling. The worst part for me was tightening the rails down and all the creaking that occurred (despite being under the torque spec). Seemed to go fine but made me nervous, I don't know how often I'd want to relive that. Personally I like the look of the bare rails so I'll probably keep them on all the time and only put carriers on as needed. Yakima has a nice bike carrier that mounts the same way quick and easy as well.
Hi, the roof rack is great. I transported my ski box on it. Only issue: the vinyl pads are not something to keep. After taking the rack off my model 3, i threw away the protective vinyl items.
Question: has anybody found replacement protective vinyl pads (the thin translucent vinyl stickers is what I mean, to put directly on your paint, to protect the paint).
I looked only, but cannot find it anywhere.
