Since I have one of the fist 2022 LFP cars delivered in North America, I thought I’d give a 90 day update. My car was delivered on Nov 13th with 15 miles on the odometer. Odometer was 2454 this morning.
The short summary is the car reported 271 miles after a full charge last night - 0.4% loss,if that’s what it really is and not just a BMS calibration. For more details, read on…
Environment:
Vehicle sits outside 100% of the time (parked in my driveway, not covered). I’m in San Jose and temps since delivery have ranged from low 30’s to high 70’s. Mid 40s’ to mid 50’s were probably the most common temps during this period.
Use:
Primary use of the vehicle has been for my work - private music instruction in clients’ homes. I drive from my home to the first client (15-20 miles highway), spend about 1 hr at the client’s home, then drive 2-6 miles to the next clients home, repeat multiple times, drive home. Total about 40-50 miles a day, mostly after dark, and most miles are freeway going to/from my home to the client area. I made extensive use of the HVAC in November and December when temps were lower and humidity was high. As temps have warmed, I’ve been using the HVAC less and Wh/mile continues to improve. Lifetime average is 219 Wh/mi, but current use is under 200 Wh/mi.
Charging:
I charge the vehicle to 100% and then drive until there is not enough charge left to get through the next day’s use. Recently that has meant charging once per week - Level 2 at home. Zero Supercharger use so far.
This week is fairly typical of what I see, so lets look at the numbers:
214 miles traveled, 199 Wh/mile, 18% battery remaining. That means I really used 60x(1-.18)=49.2 kWh, and efficiency is really 49,200/214 = 230 Wh/mile when we count the vampire/idle drain. Looking at it another way, 214x199= 42.6 kWh, therefore 49.2-42.6 = 6.6kWh was consumed while the car was parked (11%). It was exactly 1 week between charges, so that’s 943 Wh lost per day (about 1.6% per day).
Though the idle drain is a bit high, overall I’m extremely pleased with the car. It is still amazingly efficient while still somewhat sporty and fun to drive. My use case is allowing the BMS to see the battery at various states of charge and minimizing the average charge state, which should yield a long battery life. Time will tell, but so far so good!
