Anyone?
I am guessing its a rub mark from some stone that could have trapped between the brake calipers and the wheel.
Anyone?
Umm.. definitely notI am guessing its a rub mark from some stone that could have trapped between the brake calipers and the wheel.
A lathe?
They are, that's why the wheels are now 18" and 19".Anyone think they will do 20"s at a later date? Have my heart set on them after seeing the Alphas. I thought the production cars were always meant to be better than the first shown iterations.
Does anyone know the reason for the five raised areas where they used to put weights?Heres a good look at the v spoked wheels.
Sure, assortedbread posted the base wheels. The spokes are straight with no implied aerodynamic purpose.Can somebody point out what's expected to be the default wheels, and what are expected to be the premium?
I'm bad at noticing this stuff.
Are those process marks like ejectors on a die cast part, or there for vibration reasons?
Either just initial casting for the wheels and those will go away, or they are intended feature for cosmetics. Each "bump" is centered within each v-spoke arrangement.Like you say, they may just be from the initial casting. These wheels maybe like a Beta wheel? I would be surprised if those raised areas were there on the final product as they don't add anything. They are symmetrical so most likely have little effect on balance.
I do like them for a base wheel. They should look great once the center hub/nut caps are in place.
View attachment 228828 What is the channel inside the wheel for?
Why would you think hankooks aren't ready?I wonder if they changed their mind or if the Hankooks are not ready yet.
Model 3 to get Hankook Tires
Yes indeed. We need the bolt pattern. I need it in order to get my 3rd party wheels built.Once we know the bolt pattern, required rim diameter to clear the brakes, and backspacing, we can either get or have made a classic set of old school aluminum slot wheels, it would look weird on the 3, but better than some wheel designs I have seen.
This is very important. Are you sure? Link?The bolt pattern is identical to the Model S/X wheels ... also a perfect match to OEM BMW wheels
Offset: +40
PCD: 5X120
Center Bore: 64.1mm
Lug Nut Spec: 13/16 Hex 14x1.50 Thread
Lug Nut Torque Spec: 129 lb-ft.
There is also a rib for a two valve setup?View attachment 228828 What is the channel inside the wheel for?
I don't mean any disrespect, but your rims look just like the Model 3's "V spoke" rims. What am I missing?
