Thats what I thought.... but was hoping the rims would fit.Nope. Different bolt pattern.
We've been gathering interests to see if Model 3 owners would love to have a direct fit flow forged wheel that will accommodate for both the performance upgrade and the standard models.. so far, not a lot of interests yet so nothing has really taken off. Here was a quick render we did with AG Luxury's AGL27
I know forged wheels sometimes require different designs because of how they're made but is it possible to make the spokes a bit thicker? I've been looking for a good Arachnid look-alike but all their spokes seem too thin to me. Also what would be the price on these?
Can't you use a 5x120 to 5x114.3 hubcentric adapter to make these wheels work?
Those adapters need to be a minimum of 20-25mm.
The Arachnids are 21X8.5 +40.. 25mm spacer, you're looking at 21X8.5 +15. really aggressive fit.
Aggressive in terms that it’ll stick out. Stock 18’s have the same width and offsets, so it’ll stick out by the amount of the spacers, 20-25mm, (around an inch), it’s not so bad if the car is lowered especially rear fitment, but fronts may stick out a wee bit
iirc, there may be adapters around 15mm that converts bolt patterns, but the wheel itself need to have some space in the back because the stock bolts will protrude
Dang....definitely don’t want the ricer look.
Love that!We just release our 19" & 20" TSS Flow Forged Wheels for the Model 3
Black Model 3 with 20" TSS Flow Forged Wheels in Matte Black and Matte Carbon Fiber Trunk Wing.
View attachment 377321 View attachment 377322 View attachment 377323
The TSS is manufactured in a flow forged process, and each wheel is load rated at 680 kg.
The T Sportline TSS is intended for the Model 3 owner looking for a similar look to the 21" factory Arachnid wheel on a Model S. Each 19" TSS is load rated at 750kg/1,650 lbs.
