Hi,
where to find your gap filler plastic?
thanks
I have a 3D printer.....I make them per order. I just mailed one to Netherlands.
At the local paint and body store. I want to clarify something, do not fill the parking sensors only with plastic body filler-first weld it closed with mesh and welding plastic then smooth with plastic body filler. On another note-the welder plastic filler came with the plastic welding kit- u can fix just about anything plastic with it. Highly recommend as a “for life tool”.Hi,
thanks
If you need a quick rundown of a bumper refresh retrofit, I made this video as a resource (also shows Charles' 3D printed part):
Thanks Charles! I may have bought the new louvers, but I ran out of time (and honestly didn't want to spend the money). I didn't move the horn or the homelink or the hood lever. You will notice from the video we hid trim the Tesla Badge Support bracket around the homelink. The new bumper didn't interfere with the hood latch at all...Thanks so much for the post! You've by far made the best video of the process. I didn't have the guts to cut my bumper, so I bought the new louvres which are a direct fit. Anyone scared to cut the bumper and mess it up, just buy the new louvres which are plug and play. One thing you didn't show was moving the homelink sensor over. I'm sure you ran into that. Did you also have the issue with the hood lever? I had to remove the plastic knob on my hood lever.
I’m assuming you only had one latch as I did not watch the video but have installed plenty of bumpers. Older model s have two latches which is why some may have to remove the latch. As far as other parts I don’t believe it’s necessary to relocate them either however it is recommended to relocated the the temp sensor if you live in warmer climates as it can effect the readings when you install the newer bumper. Other than that if you understand how to cut the v-stripe hardware you can successfully install the bumper without relocating anything. I’m going to watch your video cause I can always learn something new and better.Thanks Charles! I may have bought the new louvers, but I ran out of time (and honestly didn't want to spend the money). I didn't move the horn or the homelink or the hood lever. You will notice from the video we hid trim the Tesla Badge Support bracket around the homelink. The new bumper didn't interfere with the hood latch at all...
Great Video
Here’s what the oem facelift bumper looks like. Its identical to Tesla’s and has all the same holes and mounts included to mount the parts too. It cost around $800 brand new unpainted not including shipping. When I went to the Tesla service center their bumper over $600 unpainted before taxes and Tesla now charges $1,480 for their bumper as they only sell them painted.
It’s a remanufactured unbranded bumper that my friend gets. Idk who makes it. Maybe since it’s a direct copy of Tesla’s bumper they might not be able too manufacture it legally. It’s not made in China and is extremely light unlike unplugged’s bumper which is one of the heaviest bumpers I’ve ever encountered. I do not like how unplugged’s bumper is made, the material used is not like most bumpers. This one is extremely flexible and comparable to the nose cone bumper, basically identical. The prior design bumper is also stiffer than it but definitely still extremely light however feels much more delicate to potentially crack or damage when handlingI'm not sure what you mean when you say it's "identical to Tesla's." Is this an aftermarket part? If so, where is it from?
Figured I would try the grill filler out but no need. The hood gap is surprisingly small and I did what I’ve learned from Nicola Brussels and screwed the covers down to cover the top of the V stripe hardware. This was using the Oem Tesla unbranded Bumper I just got. I don’t even have the mounts to screw the bumper and v stripe to the the mounts. By far the easiest bumper I have ever worked with.I make them per order. I just mailed one to Netherlands.
I would assume it would considering the harness is for the parking sensors and fog lights.I hear the wiring harness is shorter on the old bumper. Would a harness the new bumper fit on a pre-Facelift
Hi Victor P85- can you please share the shop info. I would love to bring my car there to have it done. Thank you very much.
Jus send him a PM
Charles Chen did you get my message? I wanted to see what we could potentially do with the UP V-Bar I have before I sell the bumper. To me that’s worth more than the bumper lol, for anyone doing the conversion and not adding a new hood
If anyone knows someone looking for a facelift bumper I have s brand new one primed with the pre cut holes and park assist retainers and fog light brackets already mounted. If you live in So Cal or Arizona and are not handy I can do the entire install for you
I also have an Unplugged Performance facelift bumper. I actually installed the fog lights and louvers so if someone did want it they could just swap parts with me and most the work is done.
Does the UP Vbar fit the OEM bumper?
Do you have refresh bumper brackets for sale
