Where did you get the raw sheets from? I also have a small/hobby laser so if it’s from Amazon I can try buying them and cutting them for the sport of it. Will probably fail but at least we will knowGuys I’m going to make one final adjustment tomorrow to the front, need to add back about 1/4” of profile and correct a 2 degree inward cant…
Then I’ll publish the templates as well as figure out a way to make a few sets for forum members.
If anyone is in the DFW area and has access (and knowledge) to a jeweler/scroll saw that would make my life a lot easier. I cut these 4 out by hand with a plexiglass scoring blade. It’s backbreaking work.
Very nice. Shouldn't the textured surface face out, instead of in? That's typical of other flaps.
I agree with this!Very nice. Shouldn't the textured surface face out, instead of in? That's typical of other flaps.
Where did you get the clips and bolts. Item number for those?
The textured surface faces in so it will conceal damage from rocks over time (they blend in with the texture). Smooth surface faces the car so it will not trap particles inbetween the car and the flap over time.Very nice. Shouldn't the textured surface face out, instead of in? That's typical of other flaps.
Amazon:Where did you get the raw sheets from? I also have a small/hobby laser so if it’s from Amazon I can try buying them and cutting them for the sport of it. Will probably fail but at least we will know
Sold. Please take my money.The textured surface faces in so it will conceal damage from rocks over time (they blend in with the texture). Smooth surface faces the car so it will not trap particles inbetween the car and the flap over time.
Thanks, just ordered. Let's see laser vs this thingAmazon:
Install Bay 89-00-9032 ABS Plastic 17x21x1/8-Inches https://www.amazon.com/dp/B000K4YNL...abc_A667YBHJP42GY4ZF8XTB?_encoding=UTF8&psc=1
By the way, do you have a vector model you can share, so I can try cutting it out with the laser?Amazon:
Tik-Tok-Tik-Tok, It’s Winter and No Tesla flaps for the rock. This is a crock, since even Ford, Honda, Toyota and more, certainty have them in stock.I emailed RPM Tesla and they said they have new mudflaps coming this fall for the new model s!
Nice ditty!Tik-Tok-Tik-Tok, It’s Winter and No Tesla flaps for the rock. This is a crock, since even Ford, Honda, Toyota and more, certainty have them in stock.
Awesome! I’ll have the patterns posted in a day or two.Thanks, just ordered. Let's see laser vs this thing
I can produce one for you. The designs were cut in Fusion 360 so I’m sure I can get them into vector files somehow.By the way, do you have a vector model you can share, so I can try cutting it out with the laser?
