Model S Wireless Phone Charger in Tesla Store
Ahhh...Smart! Did you find the correct part number? There are two: 1546873-00-B and 1546873-00-C
I'm guessing the one for my 2018 Model S is the latter, but how do you tell?
1546873-00-B yields NO results, so they're either not selling it anymore or it's the wrong part number.
I’ll see what I can find out. In the meantime, this looks like a good alternative if Tesla no longer stocks the OEM one:
1060585-00-B is the plastic trim used with the charging pad (#35) while 1546873-00-C is the actual charing pad (#41)
I suspect 1546873-00-B is an older rev of the charging pad and is no longer available. Fingers crossed Service/Parts can still order the two items above.
Reactions: Tezzie
Anyone had any issues with these chargers? I had greenmission’s (mentioned a couple posts above) on my 17 MS, and encountered frequent MCU_w095 errors, which essentially took out the sentry/dashcam from recording to my Tesla-branded (and Samsung also) USB drives at random.
The SC here asked if I was using a wireless charger (which I was - greenmission’s); as per the attached screenshot they mentioned they’ve encountered (or speculated) interference (from the magnet aspect of the charger, I’m assuming).
Seems everything aftermarket I try backfires, so I was wondering if anyone’s had a similar experience - and if the Tesla version might be the solution here. GM’s support disclaims any knowledge of a known issue and thus refuses to accept a return.
Thanks!
Reactions: james2441139
As an aside to this thread, here is an additional TMC wireless charging thread one may want to check out as well:
