You have a P90DL and it's 90% is 189?forgot to mention mine is a P90DL![]()
Do any of the firmware updates correspond with your drop? The recent changes to TeslaFI and Your Software Updates page would show that: TeslaFi.com Tesla Model S X 3 Data LoggerThis is what I’m seeing on TeslaFi. Seems that I’m below the rest of the 100D that they’re tracking
They said as long as it charges to 100% they cannot guarantee actual mileage to any stated miles, whether rated or ideal.
it's for use in Europe where it matches WLTP methodology I think.Quick question, what is the purpose if the ideal range?
Also, avoid charging at very high speeds often (Supercharging, CCS at high speed chargers etc.) as charging so fast put's an immense strain on a battery. They where not designed for that. All of this has been explained a thousand times, by both Tesla and many others.
What is your charge % when you finish going the 239-241 miles? You are correct, 90% of 295 is about 265 miles, however that would mean you are going down to 0% to get to 265 miles. I assume you are closer to 10%, so that would be about right. There are actually many other factors such as A/C or heat use, terrain, etc. I posted this on another thread earlier today:I have a 2018 model x 100d. Supposed to get 265miles on 90 percent charge. I am getting 239 to 241 miles on a 90 percent charge.. car its 31k miles now. Is that normal? I do sometimes charge at a SC station.
I have a 2020 Model X LR Plus. Purchased in12/2019. 33k miles. Full range showing 332 miles. Have used the Superchargers frequently. Typically charge to @85%.I have a 2018 model x 100d. Supposed to get 265miles on 90 percent charge. I am getting 239 to 241 miles on a 90 percent charge.. car its 31k miles now. Is that normal? I do sometimes charge at a SC station.
Well I always charge it to 90 percent which suppose to get 265 miles. Befor road trip I get 242 miles. The degradation seem quite alot from 265 miles to down to now 241. I recently took a 700 miles road trip last couple weeks.. I charged it couple times now and I never got back to 242 miles. Driving always the same. I wonder if my battery will get worst. Im imagining if I go another road trip will I lose another mile? The tech said my battery its normal but I just think it's bogus what they say.What is your charge % when you finish going the 239-241 miles? You are correct, 90% of 295 is about 265 miles, however that would mean you are going down to 0% to get to 265 miles. I assume you are closer to 10%, so that would be about right. There are actually many other factors such as A/C or heat use, terrain, etc. I posted this on another thread earlier today:
"My 2018 MX100D with 49,000 miles and mostly supercharged is at about 6.5% degradation, maybe 20 miles off range of 295 miles. Scan my Tesla shows Nominal Full pack of 93.5 kWh. Around town I actually get better range numbers, but on the highway where I spend most of the time at 75-80 mph I usually only get 3-3.5 hours or 230 miles on a start of 100% charge to 10%. Subsequent segments are usually 150-175 miles as you don't charge to 100% on the road unless you are stopping for an extended period of time. Speed really affects range. When I am on roads with a speed limit of 55-60 mph I could go a lot closer to 290 miles on a charge."
So what miles ur getting at if your charging 100 85 percent. Your model x 2020 100 percent charge suppose to get 335 I think.I have a 2020 Model X LR Plus. Purchased in12/2019. 33k miles. Full range showing 332 miles. Have used the Superchargers frequently. Typically charge to @85%.
