Totally normal and the battery warranty doesn't cover degradation.hi all,
Looking for advice on this:
I’m at 21k kilometres and 3.84% range loss. Went from 475km EPA to 456km. Is this expected? At which point can I use the battery warranty?
...How do you calculate degradation?...
...20-30 miles a day, but it seems at the end of day when i charge, im as low as 130-150. How do i know what is acceptable and when i should raise the red flag? Also, sometimes I do have to visit family which is a straight highway, no elevation 40 miles shot. when i do the navigation, it comes to about 20% for the 40 miles, so 80 miles is 40%, is this also acceptable for a 2016?
How many times have people on the forums indicated that the SC's won't do anything about battery degradation, not to mention that I addressed it with them on my S60 a couple of years ago. Show me in their policy where it gives an actual number relating to battery degradation and I'll gladly concur with your speculative comments.Yes it does, but it’s a rather gross measure. No more than 30% loss in 8 years. But if you had say 20% loss in one year something is likely wrong and should have it diagnosed. If it’s a real fault, they would probably find it and fix it.
The battery warranty has definitely been updated very recently, there was no previous mention as to a percentage of the battery capacity being guaranteed. I just looked at the Tesla website and see that they now mention this. I also noticed that the 8 year infinite mile warranty has been adjusted to 150K miles.It’s in black and white under battery warranty. It’s 70%.
There have been tons of whiners griping I lost 3% or 5% over some short period. 90% of those are battery measurement calibration. The other 9% are real degradation and well within spec. 1% of the grips are real, usually large and don’t follow the corrective path. Problem is they get buried by the other 99%. There are folks that had real problems with batteries and got them replaced.
Based on posts it does not take to much pressure to get Tesla to run a remote diagnostic on the the battery and that often leads to deeper investigation if something is really wrong.
Do some searches on the forum.
This is totally normal. Just as a point of comparison, my 2017 MX 100D lost about 5% of rated range in the first year, between approximately 5000 and 13,000 miles. It is now at 34,000 miles and has held essentially steady.hi all,
this is some strange info that does not match my experience.New Typical degradation within the first 12 - 18 months is apx 5% and then it should level off.
depending on when you got it, there was a rated mile change from 324 wh/mi to 332wh/mi mid-year that might make it look like it lost more rated range than the actual battery has degraded.my 2017 MX 100D lost about 5% of rated range in the first year
No, that doesn’t apply to me. I got it end of 2017 and didn’t start using Teslafi until 2018, which produced the plot I shared.depending on when you got it, there was a rated mile change from 324 wh/mi to 332wh/mi mid-year that might make it look like it lost more rated range than the actual battery has degraded.
How do you calculate degradation? New owner of a 2016 X w/47k, i charge to 90% every night and it gets me to 205 miles. i only use, at most, 20-30 miles a day, but it seems at the end of day when i charge, im as low as 130-150. How do i know what is acceptable and when i should raise the red flag? Also, sometimes I do have to visit family which is a straight highway, no elevation 40 miles shot. when i do the navigation, it comes to about 20% for the 40 miles, so 80 miles is 40%, is this also acceptable for a 2016?
