Wow! I cannot understand why there is not a white (at a minimum, yellow would be better) cross hatch/ diagonal/chevron "don't drive here" paint job for the lane to nowhere.
We have markings like that picture where you are not supposed to change lanes.
I haven't read anywhere that the injuries sustained by the driver were burn injuries. What I understood is that, a good samaritan (or two) stopped and pulled the guy out of the car BEFORE it caught fire. They couldn't have really pulled him out if car was already on fire...
I would have to do some thinking but I'm curious how a Volvo XC90 would hold up in a similar situation. I haven't read all the posts in the thread but I didn't hear of other injuries the driver had besides burns. If there were no burns/burning then I wonder if the driver could have been capable to open the rear door to evacuation a child from an accident. On that note, I understand the falcon wings door are extremely heavy to lift in the case of no power which is a concern.
Yes chevrons like these would really help. Europe does this much better than the states.
The cause of the fire is obvious. The battery case was smashed, leading to the cells or other parts of the module shorting together and causing the cells to overheat. This process does not happen fast like a gasoline fire, it takes some time to develop. The problem is that it's hard to put out because it's encased and the electrolyte is inherently flammable.Hope Tesla figures out the cause of the fire and implements upgrades to elevate future fires. This was probably a good lesson for other EV makes. So sorry for the driver!
Considering the crash structure absorbs a constant amount of energy, everything else equal, in this particular crash type, a lighter car would have fared better. i.e. I'd choose the smallest car that aces the EuroNCAP / IIHS overlap and IIHS small overlap tests.Can you pick a different car you would have preferred to be in under those same conditions or any other crash?
The cause of the fire is obvious. The battery case was smashed.
Apple also has a facilities in Sunnyvale where going straight on 101 is the thing to do. So I don't think we can conclude anything about his destination w/o more information.
A few folks have mentioned that he worked for Apple. I haven't seen a source for that though. Did I miss that?
drove by this morning and the crash attenuator is still collapsed..
All the publicity (including this thread, perhaps) seems to have called them into action.
Tesla already added super high strength shields to protect the pack from road hazards that could pierce the pack from underneath.
But this horrific accident looks like a worse case scenario - a jagged edged, narrow, fixed object made out of ultra high strength metal being run into at freeway speeds.
Personally, I don't think they can really plan to handle events like this safely. I am more concerned that highway departments leave objects of this type in the middle of the freeway.
It seems like the barrier acted like a fork that grabbed the front of the X, and then broke off the rest of it and flipped it over.
I don't know how feasible it would be for Tesla to make the front bumper strong enough to withstand such an impact.
The barrier was supposed to be in a state to absorb (most of) the impact energy, and not use the steering rack, and gearbox as the impact absorbers.
The idea behind the older highway barrier was soft materials (plastic barrels with sand).
The idea behind the new barrier is nearly indestructible solid metal... ( But with non-functioning mechanism intended to absorb energy. )
Personally I would rather run into something soft and pliable.
All the literature I ready about that smart cushion talks about how it can absorb impacts if you run into it when it is retracted and ready.
I didn't see any info on what they expect if you run into it already impacted/crushed.
To me, it looks like it has transformed into something designed to tear open the front of a car and break it apart.
Not entirely correct. The “idea behind the structure” was indeed to absorb energy by design, and based on the photos of he accident, had been completely utilized in what appears to be a textbook fashion.
Unfortunately the X is a heavy vehicle, and the energy absorbed by the structure wasn’t enough to save the driver. Very sad indeed![]()
