xanatos
This is a long shot considering how old this thread is, but here goes...Problem identified (for real this time, parts on order)
Ok...I was still having the same issues even after the window regulator replacement. So, one has nothing to do with the other. To repeat the issue I am seeing: When I initiate door open from any of the door open initiations (door handle, MCU, FOB) the door starts to open with a door latch cycle, the door stops at the ajar position with latch still in the latched position, then the ice breaker pushes the door along with another latch cycle finally opening the door.
I continued my troubleshooting this weekend. I removed the latch thinking it must be the issue even though I replaced it with a used one. I opened it up as detailed in my pics. There was a broken piece inside the latch case. It was a teflon part that was broken. This piece must be the culprit. As I stated before, I replaced the latch earlier, but with a used one off ebay. It also was presenting the same issue but less frequently (works about 25% of the time). My observation is that the teflon piece in with all the metal gears gets worn out over time or breaks. Worn out probably is the intermittent working scenario. Broke is the never works scenario which the two latches I used presented. In either case they presented the identical fault hence my conclusion it must be the latch. So, with that being said, I am ordering a new latch directly from Tesla assuming the teflon piece would be brand new and in working condition. It is obvious this piece is meant to be the first point of failure in the latch case.
I will give another update when I replace with a new latch (not a used).
I have the same issue and am trying to buy the same part. I saw one on eBay with the same part number, but the connector only has 3 pins, whereas yours has 4. Any ideas why that is, and if the 3 pin part will still work?
Pic:
