Ur car works now?
Once I get the car repaired, I will compare Wh/mile with and without a trailer.How much does it change your Wh/ mile?
I will as soon as the car is repaired. At the moment, I can not drive it except at very low speeds.Could you post what is your MX rated Wh/mile (as shown in the energy app)?
Thanks
Thank you for the reply! Actually there is no need to drive the vehicle in order to see what is rated Wh/mile. As an example, below is the snap shot of energy app from my car. The solid line at 300Wh/mile (noted with word "rated" on the right side of the screen) signifies that "rated" energy consumption for my car is 300 Wh/mile.I will as soon as the car is repaired. At the moment, I can not drive it except at very low speeds.
Look at that, no drama whatsoever.
How much does the boat weigh? It doesn't look too heavy.
She is a 23' twin engine boat. Loaded with gear and fuel she is about 4,850 lbs.
I couldn't even feel her behind the X. Felt better than towing her with my Navigator
I was surprised and quite impressed!
I suspect that is because the X has so much more low speed torque than the Navigator. The X makes towing seem effortless compared to an ICE.She is a 23' twin engine boat. Loaded with gear and fuel she is about 4,850 lbs.
I couldn't even feel her behind the X. Felt better than towing her with my Navigator.
I am told that it is around 450 +/-What's the tongue weight on that trailer?
That plus no shifting jerk and engine revving.I suspect that is because the X has so much more low speed torque than the Navigator. The X makes towing seem effortless compared to an ICE.
