Mount Transponder - Toll Roads
Discussion in 'Model S' started by smilepak, Jul 23, 2015.
Tags:
  1. smilepak
    smilepak Active Member
    Eastvale, CA
    After many tries and reading numerous threads, finally found a perfect spot that triggered the transponder every times so far.
    It's to overlap it with the black coating as much as possible because it doesn't have the coating!
  2. mikeg561
    mikeg561 Member
    huntington beach, ca
    Same here. I put my 91 express lane transponder in the same location and have not had a problem since.
    Mike
  3. Jeff P
    Jeff P Member
    Orlando, FL
    Wow... those seem really intrusive. We had something similar in Ohio for the turnpike there. Here in Florida we have little stickers you put on the glass, easily hidden behind the rear-view. They're five bucks and you throw them away if you sell the car.
  4. travwill
    travwill Active Member
    Chicago, IL
    Can you clarify exactly where this is or pics from a farther distance? Have same issues with a garage transponder. Is this in the rear now or front window, mirror, confusing pics at first.
    Thanks!
  5. smilepak
    Eastvale, CA
    Directly to the right if the rear view mirror, as high top as possible. I have a 70d but I think each car, the black area is different. The concept is to find that black paint area and cover as much of it as possible with the transponder
  6. eddie11228
    eddie11228 Member
    United States
    yes, some pics further away would be nice
  7. smilepak
    Eastvale, CA
    Ok will take when get home
  8. andrewket
    andrewket Well-Known Member
    I just completed a 3,500 mile 15-state road trip and used my ez-pass extensively. My transponder worked in some states and not others in this position. I eventually dismounted it and opened the sunroof every time I went through.
    In Illinois and Virginia the lanes don't have gates, and they will fallback to photos if the transponder doesn't work. In Indiana or Ohio (I forget which) they have a barcode scanner that you can place your transponder in if it doesn't work (this gives you an idea how common failure is.)
    In one state (Indiana?) the transponder wasn't read when I got on, but it was read when I got off. The result being I was charged the maximum amount.
    Using the license plate frame transponder is not an option for me because in Virginia we have flex transponders that have a HOV selector on it to indicate if you're currently HOV. You can't do that with the license plate. I really wish Tesla would address this problem.
  9. Ed Chan
    Ed Chan Member
    Palos Verdes, CA
    Try mounting on the rear glass. It works 100% for me in California for Fastrak.
  10. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    #10 Xenoilphobe, Jul 24, 2015
    on the rear glass on passenger side near the top are two antennas in the glass. there is no IR coating there and it will work perfectly.. they look like two defroster lines that don't terminate anywhere..place your device parallel and between the two antennas.. works great.
  11. smilepak
    Eastvale, CA
    613e060889228eb4c25a5bf1bb7224e6.jpg e5031e2f1643c485cc7e10e855b70a07.jpg 7c4bb19219978686d7349352f81311a2.jpg
    Works so far so goid
