Daniel in SD
(supervised)
200lbs sounds about right. All indications are that the AWD will have the same rear motor ad RWD. The thing is it's only 10% quicker than the RWD so either they're lowering the power to the rear or the front motor is only 10% of the power of the rear. I guess they could have raised the rear gear ratio to increase efficiency with less power at low speeds. That would actually give you more power at high speeds.I wonder what the total weight gain from the AWD setup would be. 200lbs? Also I assume power would be same to rear motor. I figured the front motor would just be for efficiency and the rear for speed. Makes me believe that on the track most of the time the car would behave like rwd which would make it silly to have AWD for tracking(not talking performance version here) as you would just be lugging around all that weight for nothing. I guess I will just b on the fence for a little while until we know more.
The front motor is induction which is less efficient than the permanent magnet rear motor.
