MS Air suspension issues
Hi all, I have a 2017 MS with air suspension, and I think I must have a leak somewhere as it drops to 'low' every time I leave it anywhere. It does go into standard and high when running, but obviously the compressor is probably running permanently to do this.
Before I start to investigate fully, is there a known weak point in the system which I should start at?
'20 Raven here - but isn't this normal behaviour when parked?
Wait.....what? So every time I get into the car after it's been parked, it's on 'low' this is normal behaviour? I assumed it would stay on 'standard' unless pressed low, high, extra high?
I'm starting to doubt myself now!
OMG I can't believe how thick I've been. The 'automatic lowering' was set to 'always' grrrrrrrrr
That depends.
If I wanted to park over the high cement block in the parking lot, I would raise my car very high. It will stay that way while I go shopping until I return and drive it away. If I return and see the car is crushing that cement block because it just lowered down on its own, that's not how it is designed.
My 2013 Model S with air suspension is now "retired" to part-time duty in Florida. Which means it can sit in the garage for more than a month...plugged in of course. But every time I return to it after such a period, the suspension has fallen to the lowest position. It does re-inflate once the car is turned on.
